Go to Post You people are online way too early in the morning... - Beth Sweet [more]
Unread 04-02-2012, 12:31
xraymypanda's Avatar
xraymypanda xraymypanda is offline
Cowboy programmer
AKA: Chris M
FRC #0599 (RoboDox)
xraymypanda has a spectacular aura aboutxraymypanda has a spectacular aura about
How to power and get feed from multiple cameras?
Hi, we are hoping to utilize two cameras this year, one for tracking and one for ball acquisition. How do we go about getting a feed from both cameras on the driver station? And how would we wire two cameras on the power distribution board since there is only one wago port for the camera? Would we have to make a custom circuit?
2011: Head Scout
2012: (figure)Head Programmer
2013: Head Programmer, Chief Strategist, Outreach Executive, and Driver
Unread 04-02-2012, 18:08
Re: How to power and get feed from multiple cameras?
To see both cameras' images on the computer running the Driver Station, you will have to set them to different IP addresses and modify the Dashboard. I think it might be as easy as duplicating the existing camera loop and giving it the other camera's address. Finding room on the screen for the second display might be the hardest part.
Is there a rule that prevents you from using the single 5 volt supply from the PDB to power two cameras?
Unread 04-02-2012, 18:13
JChavis's Avatar
JChavis JChavis is offline
Team 3490's "Pro./Electrician"
FRC #3490 (Vyper Drive)
JChavis is an unknown quantity at this point
I'm not too sure if you could do this, but here's one thing: You could just power the cameras from the Digital Sidecar 5v supply with another Wago connector. That way, you wouldn't have to cram the 5v on the PDB by having to connect the 2 cameras AND the D-link.
Hmmm....I wonder if I can create a robot lawnmower with the knowledge I have gained from FRC.....
Unread 04-02-2012, 20:25
Cowboy programmer
AKA: Chris M
FRC #0599 (RoboDox)
Thanks both of you, we managed to play around for long enough to get the cameras working. We made a custom circuit for the second camera using one of the 12V supplies and a converter. We also took a couple hours to make a 2nd dashboard window. We will post a detailed guide later for other teams to help them because we did this, for the most part, without any knowledge of what we were doing.
2011: Head Scout
Unread 04-02-2012, 20:36
You must have missed reading <R42-B>. The D-Link does not get powered from the 5 volt supply of the Power Distribution Board.
Unread 04-02-2012, 20:58
JChavis's Avatar
I'm sorry about that, I was thinking about the convertor that CONNECTS to the 12v supply, which converts it to a safer 5v supply. In that case, you could still use the supplies on the PDB and the Sidecar....
Unread 05-02-2012, 14:50
computerish computerish is offline
FRC #0619
computerish is an unknown quantity at this point
I'm looking forward to seeing the guide as our team is considering this as well. It seems like the 12V converter would be a violation of <R47>:
"Custom circuits shall not directly alter the power pathways between the battery, PD Board, speed controllers, relays, motors, or other elements of the Robot control system (including the power pathways to other sensors or circuits)"
It seems, however, that <R43> would allow two camera wires to be spliced together and then inserted into the 5V connector on the PD board:
All active PD Board branch circuits shall be protected from overload with an appropriate value auto resetting Snap Action circuit breaker. Specifically,
Each speed controller branch circuit must be protected by one and only one 20-amp, 30-amp, or 40-amp circuit breaker on the PD Board (from the KOP or identical equivalent).  No other electrical load can be connected to the breaker supplying this circuit.
Each relay module branch circuit must be protected with one and only one 20-amp circuit breaker on the PD Board (from the KOP or identical equivalent). No other electrical load can be connected to the breaker supplying this circuit.
Each Digital Sidecar branch circuit must be protected with one and only one 20-amp circuit breaker on the PD Board (from the KOP or identical equivalent).  No other electrical load can be connected to the breaker supplying this circuit.
If a compressor is used, the relay module branch circuit supplying the compressor must be protected with a 20-amp circuit breaker (from the KOP or identical equivalent). No other electrical load can be connected to the breaker supplying this circuit.
A single branch supply circuit may be spliced to supply power to one, two or three of the Analog/Solenoid Breakout Boards.  This circuit must be protected with one and only one 20-amp circuit breaker on the PD Board (from the KOP or identical equivalent).  No other electrical load can be connected to the breaker supplying this circuit.
