Go to Post There MUST BE room for mistakes. That’s one of the best ways to learn. - Ken Leung [more]
Unread 04-02-2012, 15:58
snyder.wths snyder.wths is offline
FRC #4296
snyder.wths is an unknown quantity at this point
PWM Andymark Cables
Does anybody know if the red/orange/brown RC extender cables we got with the kit will work the same as Andymark PWM cables? We need more cables but there isn't a parts number displayed on the FRC website.
Unread 04-02-2012, 16:02
EricH EricH is online now
Re: PWM Andymark Cables
Yes, they will.
PWM cables have multiple color sequences; red/white/black is one of the most common. Red/orange/brown is not one of the more common ones I've seen.
Unread 04-02-2012, 21:06
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
I'm wondering if the color code is legal with respect to rule 46:
All active circuit wiring with a constant polarity (i.e., except for outputs of relay modules, speed controllers, or
sensor outputs) shall be color-coded as follows:
A. Use red, white, brown, or black with stripe wire on the +24 Vdc, +12 Vdc and +5 Vdc connections.
B. Use black or blue wire for the common or negative side of the (-) connections.
[R46]
Unread 04-02-2012, 21:27
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
It is legal, the rule states (emphasis mine):
sensor outputs
[R46]
Basically, the rule applies to wires that are sending electrical current (not my field of expertise, so that's probably a terrible, simple way to describe it) and PWM's are SPECIFICALLY exempt from the rule/their color is not enforced.
Unread 04-02-2012, 22:56
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
If you want to make them yourself heres a link to a great shop for everything PWM you need. http://hansenhobbies.com/products/connectors/
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 05-02-2012, 13:02
Nathan4567a's Avatar
Nathan4567a Nathan4567a is offline
Circuit Master
AKA: Nathan Lerner
FRC #2587 (Discobots)
Nathan4567a will become famous soon enoughNathan4567a will become famous soon enough
Yes, they will work fine. They are both the same gauge and will conduct the current the same. When you are dealing with anything like that, you don't need to work about the brand of the connector. They are all essentially the same. The only time you should worry about the kind of cables or connectors you are using, is when you are dealing with high voltages, high amps, or any specialized electrical pulses. Do take care with your CIMs. Those can become very dangerous if you do not use the right gauge of wire or the connectors are poorly made. Pay close attention to the rule book when you are wiring those up.
