Go to Post I learned about how FIRST really is about so much more than a robot competition, it is about team building and the individual. - Adel Hodiwala [more]
Unread 02-02-2012, 22:02
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Autonomous Motor Problems
This is my first year as a programmer for my FRC Team, but I have a Java background to work off of.
I am using Netbeans 7.1 with a default program with IterativeRobot and SimpleRobot subclasses. Both are default programs that I have used for testing verbatim and the results, after I have fixed electrical and network on the Classmate (2009) issues, is the Timer.delay() function.
Following examples are from the SimpleRobot program, the IterativeRobot program is the BuiltInDefaultCode code.
In Tele-Op, the motor will respond to the joystick and, by default, has a the delay set to 0.005 seconds:
driveTrain.tankDrive(leftStick, rightStick);
Timer.delay(0.005);
In Autonomous, it has a 2 second value with a movement at half speed.
for (int i; i < 4; i++)
driveTrain.drive(0.5, 0.0);
Timer.delay(2.0);
The issue is that instead of holding the motor value until the seconds expire, the Jaguar and motor will move for a split second and wait the entire 2 seconds until repeat.
If anyone has any solution, question, comment, advice, anti-Murphy's Law Orbital cannon, or other pieces of help, it would be GREATLY appreciated!
Thank you in advanced!
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 02-02-2012, 23:29
neal's Avatar
neal neal is offline
Neal
FRC #1777 (Viking Robotics)
neal is an unknown quantity at this point
Re: Autonomous Motor Problems
For the motor's safety, if it doesn't get called often, it'll automatically stop it. And Timer.delay() stops the whole thread.
I'm assuming you want to run the motor for 8 seconds, this is one way you could do:
public void autonomous() {
	Timer timer = new Timer();
	timer.start();
	while (isAutonomous() && isEnabled()) {
		if(timer.get() < 8) { // Double check this; don't exactly remember what it returns
		Timer.delay(0.005);
	timer.stop();
Unread 03-02-2012, 21:08
Student
AKA: Marco Schoener
This is what I pulled up for the Timer.get() API
get
public double get()
Get the current time from the timer. If the clock is running it is derived from the current system clock the start time stored in the timer class. If the clock is not running, then return the time when it was last stopped.
Returns:
Current time value for this timer in microseconds (uSeconds)
Will the new timer implemented within the method auto-start at 0 or will it have some other start area. And if it was started, would I subtract a [<desired time> + old time] - old time or what?
Any suggestions or comments would be very helpful and greatly appreciated.
Thank you again and continuously in advanced!
Team 1369
Senior
Head Electrician
Unread 03-02-2012, 21:37
neal's Avatar
Neal
So you the 8 would be 8000000 for 8 seconds, since it returns microseconds.
All Timer's you create are independent from each other. You can start, stop, reset each Timer whenever you want.
Unread 03-02-2012, 22:35
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
I disabled watchdog (this was two years ago) when I was doing autonomous for programming. Try doing the same with motorsafety.
Just make sure you start it again during teleop
Unread 04-02-2012, 17:45
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
Nonono you dont need the for loop or the while loop... All you do is do a simple drive function and then put Timer.delay(8); and then after that set the motors to 0 speed. You dont really want a while loop in autonomous because then you will be doin the same thing over again and I dont think you would want that...
Unread 04-02-2012, 21:03
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
SimpleRobot only has one thread. If you look at the Timer.delay() method, you'll see that it calls Thread.sleep(). You aren't able to do anything until the Thread wakes up again.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 04-02-2012, 23:07
Student
AKA: Marco Schoener
Well the issue is that whether there is a loop or not, it still stops for a split second and uses the delay() as the "do nothing" time. Can you be more specific, a simple code example perhaps?
Team 1369
Senior
Head Electrician
Student
AKA: Marco Schoener
Then what is your solution Djur, because the API does not have many solutions.
Team 1369
Senior
Head Electrician
Unread 05-02-2012, 00:49
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
One of the (sometimes) more annoying aspects of programming a robot is that everything has to be "refreshed" periodically. Certain sensors have to be sampled at a high rate to get good results, speed controllers will stop if you leave them on for too long without setting them, etc. This means that programming a robot actually lends itself fairly well to the IterativeRobot setup: you write your Continuous() and Periodic() methods in a way that won't actually stop the robot from running.
In your case, the best idea is probably to do something like this:
Timer t = new Timer();
t.start();
while(t.get() < TIME_LIMIT*1000000)
    doStuff();
where TIME_LIMIT is your desired length of time in seconds, and doStuff() does stuff (in this case sets motor speed).
If you look at the source of WPILibJ's Timer class, there are a few interesting features: a method reset(), which resets the Timer's value to 0; a constructor which actually calls reset(), meaning that a new Timer always starts at 0; and stop(), which, although it may seem counter-intuitive, does not actually reset it, just prevents it from counting any further. Basically, it does what you want and keeps all the "old time" stuff behind the scenes, so you don't have to worry about it.
