Go to Post I got to talk with Mr. Flowers briefly last year. I told him that I had wanted to be part of FIRST since about 1980. It was nearly a quarter-century later when my son entered high school and I joined the TechnoKats as a mentor. - Alan Anderson [more]
Unread 05-02-2012, 01:39
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Idler Sprockets
Make the Delrin a cam shape while you're at it, if you can, or make it slightly oversized. Gives you a tensioner built into the system, which can be helpful if you have problems with slack chain or tight chain.
EricH,
Keep in mind that the shaft under the tensioner has to rotate unconstrained to the idler. I think I will try to have the bore made oversize though. Having tried to get some .374 ID spacers on that shaft earlier today, I don't think I'll make the same mistake twice...
Unread 05-02-2012, 03:27
aheg1220 aheg1220 is offline
FRC #0599
aheg1220 is on a distinguished road
Re: Idler Sprockets
Just make a temporary bushing out of aluminum until you can get your hands on some bronze bushings.
