Go to Post C'mon you guys you're all inventors. You guys should be making a portable cryogenic sleep chambers for those long bus trips! You got two weeks before you have to go. Get cracking! - Koko Ed [more]
Unread 01-02-2012, 17:34
Quellek2 Quellek2 is offline
FRC #4121
Quellek2 is an unknown quantity at this point
Exclamation How do we get the scroll wheels (behind buttons 8 and 9) on the attack3 to interface?
We want to use them as a way of controlling the max power, but we have no idea how to get data from them. Anyone know?0
Unread 01-02-2012, 17:50
Re: How do we get the scroll wheels (behind buttons 8 and 9) on the attack3 to interf
It's axis 3.
Unread 02-02-2012, 10:02
sometimestommy's Avatar
sometimestommy sometimestommy is offline
Schrödinger's Assistant
AKA: Thomas Moll
FRC #1939 (Ku-Nig-Its)
sometimestommy is on a distinguished road
Yes. It is axis 3 on your joystick.
All you have to do is to unbundle the joystick and then "select" axis 3 from the context menu on the unbundle by name.
Important! Check the value on the scroll wheel as it could go past 1 or -1 which is really bad for motor control (since they only go to these values)
-Team 1939 The Barstow Ku-Nig-Its!
Unread 02-02-2012, 16:40
FRC #4121
Huh. Not sure how I missed that one. Thanks!
Unread 05-02-2012, 02:04
Wildcat Robotic Wildcat Robotic is offline
FRC #3039
Wildcat Robotic is an unknown quantity at this point
If you take the value of Axis 3 and add 1 then divide by 2, it changes the scale from [-1, 1] to [0, 1]. Just a helpful hint if you wanted to use it to control one direction of a motor.
