Go to Post ...your mentors are your friends. If you're not sure of something, they probably know the answer to it, and if they don't, they will point you to someone who does. - Karibou [more]
Unread 02-05-2012, 07:38 AM
acastagna acastagna is offline
FRC #1493
acastagna is an unknown quantity at this point
Netbeans Intaller error
My team's programming group has two laptops for development, and one has decided to stop running netbeans version 7.1. The computer is a nexlink running windows 7. It worked fine for the first 3 weeks of the season, then one day it just stopped.
We get some sort of net.dll error. The full error message is attached . We have tried the following:
- uninstalling netbeans to start from scratch, (uninstaller gives the same error)
- installing over the existing (same error)
- installing version 6.9 of netbeans (same error)
- removing the jre folder and reinstalling java from the file jre-7u2-windows-i586 (we successfully reinstalled java, but it did not help)
- looked in the jre folder for the net.dll file mention, and found it where it was supposed to be. Downloading a fresh net.dll file and replaced the old one. (did not help)
- tried installing java using jre-7u2-windows-x64 (error stating it was not supported by this computer)
- confirmed the jdk1.7.0_02 folder and files are present. We tried reinstalling that but also get a dll error.
Does anyone have any suggestions?
- Andre Castagna
Team 1493
