Go to Post there is no such thing as too many parts or useless parts, only parts you dont need yet. - Cuog [more]
Unread 05-02-2012, 09:08
hardufy2 hardufy2 is offline
FRC #1574
hardufy2 is an unknown quantity at this point
Camera types
Are we allowed to use a camera for image processing that is not one of the axis cameras supplied by AndyMark? (of course its price has to be within the budget limitations) when you think about it, it is just a very advanced sensor...
We searched the manual for any refrence to the camera and it doesn't say a thing.
Unread 05-02-2012, 10:51
There isn't anything in the manual that prohibits other cameras. However, the software only supports the axis protocol, so you would need to write a lot of code to interface with another camera.
Unread 09-02-2012, 03:53
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: Camera types
If it outputs an image stream (mjpg), it should be fairly easy to find sample code online for it. Only problem is you would need to process it yourself without the help of the libraries. (We're doing that.)
Unread 09-02-2012, 07:14
dakaufma dakaufma is offline
AKA: David Kaufman
FRC #0449 (Blair Robot Project)
dakaufma is an unknown quantity at this point
Re: Camera types
If it outputs an mjpeg stream you should be able to adapt the existing camera library without much trouble. You might only have to change the url it uses.
What camera are you using? Our Axis 206 cameras are getting old and I don't really want to pay $160 for replacements.
