Go to Post ...SEARCH BEFORE YOU POST, and when you do post think twice before pressing the 'post' button. - Brandon Martus [more]
Unread 05-02-2012, 13:13
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
swwrobotics is an unknown quantity at this point
Gear ratios for launcher
Has anyone found that magic gear ratio that works best for the launcher?
Our team tried doing a direct drive with the CIM motor but the ball did not go very far. I remember reading that a 2.7 to 1 gear ratio works best but I can't be sure. Any ideas?
Unread 05-02-2012, 13:15
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Re: Gear ratios for launcher
We've been running 2 BaneBot 550s with 20:1's and they work beautifully. We may just be able to pull off our master strategy after all
Academic Student (Forever)
Unread 05-02-2012, 13:19
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
The gear ratio depends heavily on the diameter of your end effector, assuming you're doing a roller/wheel shooter. Direct-driving with a CIM to a 1" roller is very different from an 8" wheel.
OP, care to provide any details? My team's experiments show that you should find the exit speed you need for your range, assume the ball will go 60%-70% of your theoretical tangential free speed, and gear accordingly.
Unread 05-02-2012, 13:26
It depends on the motor(s) you are using, the diameter of the wheel(s), whether you are using only one wheel or top&bottom, the moment of inertia of the wheel(s), and other factors.
This post may be of interest:
http://www.chiefdelphi.com/forums/sh...5&postcount=20
Unread 05-02-2012, 13:33
CalTran's Avatar
MST Rolla Senior
Our team is using 6in or 8in wheels for our shooter, I can't remember which one. (I'm not actually on the shooting team)
Unread 05-02-2012, 13:50
We are doing a one-wheel design that uses the new six inch wheels that came in the kit of parts and a flap on the top to adjust the angle the ball comes out of.
We were just worried that a high gear ratio wouldn't have enough force to launch several balls and it would be hard to get back up to speed.
Unread 05-02-2012, 13:59
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The new kit wheels tend to tear up the balls, according to a couple of reports from teams who tried them. We're using a single 8" kit wheel from a year or two ago, driven by last year's FP motor with it's 19 tooth pinion, which drives an older FP plastic first stage gear from the FP gearbox. The ratio is 19:72, I believe. This gives us a pretty good range....
http://www.youtube.com/watch?v=81vOT2KY2ig
But the gear ratio you want will depend on a lot of factors, as others have mentioned.
Unread 05-02-2012, 14:54
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
How much compression were you putting on the ball?
Other than the fact that the tread pattern on the 2012 KOP wheels chews up the foam basketballs, any single-wheeled shooter with six inch wheels (when directly driven from a CIM) should easily be able to shoot the balls a more than adequate distance.
Simply changing the gear ratio won't solve this problem; the real problem is probably related to ball compression, shooter hood design, and/or misalignment/binding/friction in the moving parts of the shooter.
FYI: The 2.7:1 gear ratio is what is inside the CIMulator from Banebots. There will likely be a fair amount of teams using this gearbox this year, as this gearbox makes a 775 or 500-series motor "emulate" the output characteristics of a CIM motor. This allows teams without a lot of machining resources to keep their CIM motors in their drive train and use "emulated" CIM motors elsewhere on their robot.
Art Dutra IV
世上无难事,只怕有心人.
Unread 05-02-2012, 15:21
Our mentor said the we should have as little amount of contact with the ball as possible to pervent too much deformation and loss of accuracy. So you're right, that definitely could be the problem. But just out of curiosity, would it be worth more to have a high gear ratio or a larger wheel diameter?
Unread 05-02-2012, 15:28
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
It's true that you should have as little contact with the ball as possible, but you still need some minimum amount of contact, otherwise you won't impart much energy to it. Many teams seem to have found that 1-2" of pinch on the ball will work well.
With a 6" wheel you could be looking for 2,000-5,000rpm axle speed, depending on what range you want. the actual ratio will depend on what motor(s) you're using.
Unread 05-02-2012, 15:40
Has anybody posted test data anywhere that includes wheel rpm, wheel diameter, squeeze, launch angle, and distance?
[edit] and wheel moment of inertia, if available? (yeah, I know: dream on) [/edit]
I've been keeping an eye out, but haven't seen anything yet. It would be most useful as a sanity check for some of the calculations.
artdutra04's Avatar
From what it sounds like, your shooter barely compresses the ball. If so, the best thing to try out first would be to increase the compression between the shooter wheel and the ball; otherwise every motor and wheel combination you can try will likely have the same disappointing results.
The trick is to find a balance between not enough compression (not enough energy from the wheel gets transferred to the ball, leading to wimpy shooting range) and too much compression (too much energy is taken from the shooter wheel without any shooter range improvements). If you do some experimenting, you'll find an a good balance between the two.
Once you find the ideal level of compression, then you can look into substituting other motors, gear ratios, and wheel sizes.
Art Dutra IV
世上无难事,只怕有心人.
Unread 05-02-2012, 15:50
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FIRST Team 1296 is trying 2 FP 801 motors at 6:1 and 2 AM motors at 4.64:1 driving 2 8" wheels (both under the ball) - have not got it running yet, a proof of concept with a CIM at 3:2 worked nicely compressing the ball 1-1/2"
HTH
Unread 05-02-2012, 17:49
klmx30302's Avatar
klmx30302 klmx30302 is offline
Is ready for MAYHEM In Merrimack!
AKA: Kevin McCarthy
FRC #0166 (Chop Shop)
klmx30302 is a jewel in the roughklmx30302 is a jewel in the roughklmx30302 is a jewel in the rough
Team 166 is direct driving 2 axels with 2 8" wheels each. Each axel has a cimulator with 2 rs-550 motors each. We have not clocked its top rpm yet but the wheels spin quite fast as you can see in this video: http://www.youtube.com/watch?v=YtiK87pE_9U
We don't know the range of the final shooter yet, but the prototype could shoot 46-50 feet, the prototype was direct drive cims instead of cimulators.
Unofficial Team 166 Videographer
Our team motto...
"THINK!, There must be a harder way!"
Unread 05-02-2012, 23:10
pfreivald's Avatar
AKA: Patrick Freivald
We're making very consistent shots from key range with AM motors and planetary gearboxes, though the spin-up time between shots is too long. We're working on that problem now!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
