Go to Post There hasn't been an announcement to buy pool noodles yet. Considering that they are already out of stores in most of the country, draw whatever conclusion that you like. - Joe Ross [more]
Unread 05-02-2012, 17:23
ArmandoSal ArmandoSal is offline
FRC #0996
ArmandoSal is an unknown quantity at this point
Forced needed to get on Bridge
Hello, I am just wondering if anyone has found out the force needed to tilt the Bridge so that a robot can get on it. Thanks.
Unread 05-02-2012, 17:32
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Re: Forced needed to get on Bridge
This was posted in another thread i saw a while back as 16 to 18 lbs of force on the most outer part of the bridge. I am not sure of these measurements however, Could someone confirm this?
Expect the best, Prepare for the worst
Unread 05-02-2012, 20:02
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
The weight of 2 batteries at halfway is needed to tip, so ~1 battery's worth is needed at the edge. That's about 13 pounds, so design for 20 lbs to be on the safe side.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 05-02-2012, 20:18
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
That's about right. To clarify, it takes ~59 lbf-ft of torque to tip the bridge.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 05-02-2012, 21:44
AKA: Jon
for teams that have matched their bridge to the specs of competition. how did you adjust the balance of your bridge? did anyone recreate the 16-18 lbs on both sides while keeping the bridge balanced? any info would be greatly appreciated.
Unread 05-02-2012, 21:54
With an extra 160 pounds of concrete blocks mounted underneath the deck, our wooden bridge now passes the "two battery" test.
Unread 05-02-2012, 22:01
jdunston94 jdunston94 is offline
FRC #3357 (C.O.M.E.T.S.)
jdunston94 is a jewel in the roughjdunston94 is a jewel in the roughjdunston94 is a jewel in the roughjdunston94 is a jewel in the rough
instead of putting aton of uneeded weight on the underside of the bridge we just put surgical tubing
and it is right around 18lbs of force perpendicular to the bridge to push it down
Unread 05-02-2012, 22:18
AKA: Jon
How did you attach the tubing?
Unread 05-02-2012, 23:56
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
We took eye hooks and screwed them into the bottom of the bridge. Then we adjusted the tubing till it met the specs.
Unread 06-02-2012, 00:10
AKA: Jon
alright thanks. i will try that on monday
Unread 06-02-2012, 10:53
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
This will not actually yield the competition bridge dynamics. How much it is off will be situation-dependent. In short though, you're now using spring force (F=-kx) rather than distributed bass to balance the moments. This means that, while you may pass the battery test, as your bridge moves, the moment caused by the spring force will not fully mimic what the simply heavier competition bridge would do. It probably won't affect your bridge lowering tests, but if you're practicing (much less autonomously programming) balancing on it, don't count on the results being the same unless you've tested it.
Unread 06-02-2012, 15:17
AKA: Jon
could anyone who has done this post a picture of the bridge with the surgical tubing set-up?
Unread 11-02-2012, 16:02
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Our bridge now meets the balance test with a bunch of old dead FRC batteries. It took ten batteries , five per side, to meet the 2012 battery test. See the attached photo. The center of the first 2x4 is 16" back from the edge of the bridge. There's plywood over the top of all the batteries when it's put together.
Unread 22-02-2012, 10:29
dcreed@epic.com dcreed@epic.com is offline
FRC #3692
dcreed@epic.com is an unknown quantity at this point
I'm confused... some people are saying 16-19lbs of force at the end of the bridge and then someonw say the ~59 lbf-ft of torque to tip the brige.. so say if using a window van motor with 25.8 ft-lbf applied to the end of the bridge? Would this tip the bridge or not?
Thanks,
Dan
Unread 22-02-2012, 11:35
Where's the confusion? The end of the bridge is about 40-48 inches from the hinge point, depending on which end, so 59 lb-ft of torque would be between 15 and 17.5 pounds.
How much force are you applying to the end of the bridge? A one-foot-long direct-driven rod perpendicular to the motor shaft could work. A two-foot-long rod would not.
