Go to Post i will not post here...i will not post here....well...okay, yes I will - David66 [more]
Unread 04-02-2012, 14:52
l0u1s3sp1n0's Avatar
l0u1s3sp1n0 l0u1s3sp1n0 is offline
FRC #4029
l0u1s3sp1n0 is an unknown quantity at this point
Shifting Gears in LabVIEW
Any ideas to shift gears in motors
Unread 04-02-2012, 16:50
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Re: Shifting Gears in LabVIEW
What 's your purpose ?
Unread 04-02-2012, 17:00
FRC #4029
Our purpose is to shift the robot into high gear so we can go faster and go into low gear to slow down
Unread 04-02-2012, 18:28
DonRotolo's Avatar
Back to humble
FRC #0832
OK, what kind of shift mechanism is being used?
Some typical mechanisms include pneumatic cylinders, Electric servo motors, and electromagnetic solenoids.
The drivetrain team should be able to answer that.
Unread 05-02-2012, 13:13
FRC #4029
The shift mechanism we are using is the electric servo motor
Unread 05-02-2012, 18:03
Use the Servo example (Launch LabVIEW, click the Support tab, click "Find FRC examples..." and look for Servo.lvproj under the FRC Robotics->Actuators folder). Play with the servo angle numbers until you get the gearbox to shift appropriately. Record those numbers; your code will use them to set the servo angle when you want to shift between high and low gear.
What physical controls do you want the driver to use in order to shift gears?
