Go to Post Stop it with the "break the rules, just don't let anyone know" already! - Alan Anderson [more]
Unread 26-01-2012, 16:41
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: Top/bottom roller shooter vs. bottom roller only
My team is going with a one wheel shooter because it is more compact for being on a turret
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 27-01-2012, 20:13
dragonman's Avatar
dragonman dragonman is offline
FRC #1243
dragonman is on a distinguished road
Ok so, I am design our shooting system and have designed a two roller shooter, however I was informed there is an optimum roller diameter based on the rpms it will spin and the ball diameter and I was told there where calculators. I found jvns design calculator but there wasnt anything about shooting. Does anyone know about any calculations and formulas I can use or of a Design calculator for this?
Unread 27-01-2012, 20:52
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
There should be an optimum diameter, but it will also depend heavily on your design, including variables like how many motors (not just RPM, torque will play a role), moment of inertia (if you have a flywheel, or just the inertia of the roller), friction in the bearings, and perhaps most importantly, how much you compress the ball. An analytic solution for the best diameter would be difficult if not impossible because some of those variables are very hard to measure and quantify. So your best choice is probably just to test a bunch of rollers until you get something that works.
Unread 27-01-2012, 21:35
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
A decent estimation is that the ball will get moving at 60-70% of the ideal free speed of your shooter roller's tangential velocity. Aim for 1-2" of pinch, with some adjustment (we're using 1.5" of pinch). Wrap your rollers in a grippy, compliant, material.
Hope this helps.
Unread 02-02-2012, 20:40
For a 2-wheel (top and bottom) shooter with both wheels the same diameter and powered and spinning at the same speed: If you assume that the ball exit speed is equal to the tangential velocity of the wheels then
wheel rpm = 720*V/(pi*d)
V is ball exit speed in ft/sec, and
d is wheel diameter in inches
For a one-wheel shooter, the required rpm will be approximately twice that.
As for motor selection and gear ratios, here are some thoughts:
http://www.chiefdelphi.com/forums/sh...3&postcount=15
Unread 03-02-2012, 15:20
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Hey Ether, why is that? Are their techniques to make it less than 2X?
TIA
Unread 03-02-2012, 15:26
Think about the tire of a car going down the highway at 60mph.
At any instant in time, the center of the tire is translating at 60 mph. The bottom of the tire, touching the ground, has zero speed at that instant. The top of the tire, at that instant in time, is going 120mph.
Unread 03-02-2012, 22:26
dellagd's Avatar
AKA: Griffin D
This needs a poll
Unread 03-02-2012, 22:56
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Excellent illustration - thanks!
Unread 03-02-2012, 23:28
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
We are talking about an observation in the road's frame of reference?
Unread 03-02-2012, 23:57
Well I did say:
...so that would be "yes".
Unread 06-02-2012, 02:13
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
But our "car" is not moving. The speed on the edge is r * omega where omega is rps * 2 * pi. If there is a second wheel above the first why would it increase the speed on the edge of either wheel? Perhaps the real issue is that single-wheeled shooters lose velocity because of the balls interaction with the hood? And double-wheeled shooters (which generally have no hood) do not?
Jeez - I should have paid more attention in physics but I don't get it. How could you possibly accelerate the ball to an initial speed greater than the speed on the edge? Happen to know any illustrative web sites?
TIA
Unread 06-02-2012, 02:51
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
TIA
The problem is very simple.
With single wheel shooters, the ball has to roll along the hood. When you make the edge of a rolling object move at 1x ft/sec, the object as a whole moves forward at 0.5x ft/sec.
With double wheeled shooters, the ball is just pushed through the two wheels. It doesn't have any backspin and leaves at a maximum velocity of 1x.
Art Dutra IV
世上无难事,只怕有心人.
Unread 06-02-2012, 06:22
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
OK, that makes more sense - and what I was meant by "interacting" with the hood. Ether's explanation also makes more sense now.
Thanks
