Go to Post If the GDC can actually top Rebound Rumble, I might cry at the reveal. - PayneTrain [more]
Unread 06-02-2012, 08:04
Re: waits
In my experience, the wait time is very accurate. How are you finding it not to be? What time are you looking for, and what do you intend to do with it?
Unread 06-02-2012, 08:12
Re: waits
You can send the data from the DS, but that will require a bit of networking.
The Match Info that is an input parameter to the teleop should be pretty accurate, and show should elapsed times. How are you testing to determine they are "not at all accurate", and how much error is that?
Greg McKaskle
Unread 06-02-2012, 17:48
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Re: waits
i tried firing solenoids once per second and it seemed like it was once every 3 seconds.
