Go to Post Yeah.... I'll pay money just for a picture of Andy [Grady] getting jiggy! (then recommend it for the Caption contest!) ;) - Rich Wong [more]
Unread 06-02-2012, 12:07
Pat Hart Pat Hart is offline
FRC #0234 (Cyber Blue)
Pat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud of
Re: Drive Train help
Are you driving in the wide or narrow configuration. If you are driving wide the added distance may allow you to turn without lowering the center wheels. In the narrow configuration you are more likely to need a lower center wheel.
I am not sure how your blocks are mounted but if possible try testing by shimming the middle wheels with washers and find what turns best for your robot. Wheel spacing and center of gravity location can have an effect, so not all robots handle the same way
Unread 06-02-2012, 12:13
With a .1" drop and a well balanced robot, you should not have troubles with being tipsy.
Make sure you drop your centers enough (would recommend .125") and balance your bot.
Unread 06-02-2012, 12:16
Samk Samk is offline
Lead Builder
FRC #0619
Samk will become famous soon enough
we are driving in a narrow config, with dead axles. all wheels are powered
Unread 06-02-2012, 12:33
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
In narrow config I would say anything from .125 to .1 would be good for 8 wheel drop center.
Our team usually does a .0625 drop, but that is because we found with a 6wdc .125 rocked to violently when accelerating from stop.
Unread 06-02-2012, 18:34
Lead Builder
FRC #0619
Thanks for all the replies! I'll show the team this and see their thoughts
