Go to Post Pro safety tip: put a string through coil springs that is tied off securely on the robot frame. This will help prevent the spring from jumping out and killing an inspector if it snaps. - Ninja_Bait [more]
Unread 06-02-2012, 12:11
Re: Gyro Doesnt Stop!!!!
Originally Posted by cilginbilgin View Post
When we turn the robot on, gyro doesnt go directly to 5000 degrees. Once we move the robot, angle of the gyro starts changing and doesnt stop even if the robot is stationary. We are deploying the Gyro Example Code in Labview, we tried to wire a constant to set gain as you said whereas it didnt work for us.
What might be the problem??
If you have the sensor board wired properly and the Gyro Example does not work, you might just have a bad sensor.
How do you have it wired? How many wires are connected, and where does each of them go at each end?
