Go to Post FIRST has set me on a completely different path in life. And I'm all the better for it. - Vincent Chan [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 23-01-2012, 18:30
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
Exclamation CAN Failure
We are having serious problems with our Jags, they all work until we start running the robot hard and they stop running except for the first on the bus and the last one. when the other ones stop the yellow light stays on like it is still connected but it never puts out any power. It seems to be the battery voltage because it only dies if the battery voltage drops below 10v which happens a lot because we have lot of motors running. Please help.
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 06-02-2012, 07:49
Superllama12's Avatar
Superllama12 Superllama12 is offline
Wombaticus
AKA: Brandon Buncher
FRC #0540 (Talon 540)
Team Role: Electrical
Superllama12 is an unknown quantity at this point
Re: CAN Failure
That definitely sounds like a battery problem, you should never let the battery charge drop below 10.5v, or it can damage the battery. Also, if that doesn't work, check each individual cable in the CAN cables with a voltmeter for shorts/breaks, and if they are fine, open the jags and check for gunk inside. Good luck!
I would put a signature here, but that's too mainstream
Wait a moment...
Last edited by Superllama12 : 06-02-2012 at 07:51. Reason: Misread the original post
Unread 06-02-2012, 14:00
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: CAN Failure
Could it be this problem?
http://chiefdelphi.com/forums/showthread.php?t=101871
