Go to Post It's always better to figure out why a design actually works and the best ways to implement it than to just assume upgrading to a "better" material will make everything work. - Cory [more]
Unread 06-02-2012, 16:41
jeremy5561 jeremy5561 is offline
FRC #0919
jeremy5561 is an unknown quantity at this point
Sun gear doesn't fit on shaft
I'm trying to fit http://www.andymark.com/product-p/am-0040.htm on http://www.andymark.com/product-p/am-0912.htm and it's not working. We already went through a motor. It doesn't fit smoothly. Am I doing something wrong?
Unread 06-02-2012, 16:54
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Sun gear doesn't fit on shaft
These two items are designed to be pressed together. It takes even pressure directly along the motor shaft axis to do it. Many options are available to do this. An Arbor press or a vice make if fairly easy. The key is to keep everything in a perfectly straight line. Any off axis pressure is going to bend your motor shaft. Make sure you are supporting the back side of the motor shaft against the vice.
Unread 06-02-2012, 17:12
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
See this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=101825
