Go to Post Canada has five regional events now. Canada. - Nick Lawrence [more]
Unread 06-02-2012, 18:30
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Drive train suggestions
Rookie Team 3992 here,
We currently made a drive train which is as so:
4 Wheels;
The two front wheels are 10 inch pneumatic wheels from harbor freight.
The back two "wheels" are 3.5" diameter swivel casters.
We thought this would allow for good maneuverability, but instead it's harder to control with the casters on the back.
However, we have been driving it:
1) On painted concrete floor (more slippery than the carpet)
2) With no weight on the drive train (pneumatics get more traction with weight, and casters may act differently)
So I ask you,
Are our two testing factors giving us the unsatisfactory result, or is our drivetrain design not very efficient and we should change it?
Thanks!
Unread 06-02-2012, 18:46
Re: Drive train suggestions
Your problem can be summed up in one word.
Casters.
Use omni wheels if you possibly can. If you must use casters, use ball casters.
While weight and the fact you aren't on carpet may have something to do with your problem (and if I were you, I'd test on carpet), casters are your problem right now.
Casters tend to do exactly what you're finding out that they do: mess up maneuverability.
Unread 06-02-2012, 18:51
ksafin's Avatar
AKA: Kirill Safin
Casters.
We'll try to test soon, but otherwise, what are the cheapest yet best omni wheels you can recommend?
We'd obviously need two dualies.
Unread 06-02-2012, 18:55
There's a blue-and-white dually type I've seen around. That's pretty decent; I want to say it's a 4" size. I don't know any more about it, sorry.
Or you can go shopping AndyMark's collection.
4" dually http://www.andymark.com/product-p/am-0381.htm
All of AM's plastic omnis (which are cheaper than the Al ones) http://www.andymark.com/Omni-Plastic-s/69.htm
Unread 06-02-2012, 19:00
ksafin's Avatar
AKA: Kirill Safin
The only problem I see is leveling them with our 10" giant pneumatics. I'm thinking 8" dualies.
Does that sound good?
Unread 06-02-2012, 19:07
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
We did a 4 wheel driver with 2 8inch traction and 2 8inch non-dualie omin wheels.
It worked out fairly well in the end.
You probably need an bracket to get the omins even with the 10inch pneumatics.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 06-02-2012, 19:46
ksafin's Avatar
AKA: Kirill Safin
We'll probably use an FTC stunt, by using a 3 unit channel attached to the bottom of our C-Channel to displace the 8 inch wheel, therefore leveling it with the pneumatic
Unread 06-02-2012, 19:58
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Easy solution to omnis, you will need the following:
  • A kit wheel of your choice.
  • Pool tube.
  • Zipties.
Take the pool tube cut to go around the outside of the wheel. Cut down the middle and put over the outside of the tube using zipties every so often to hold the tube in place. Cut the ends off of the zipties and tada! You have a poor man's omni wheel.
My old team used these in 2005, 2006, and 2008 with much success. Good luck!
See an example wheel here!
1058 PVC Pirates 2016 - xxxx
Unread 06-02-2012, 21:22
Whatever you need to use. See the AM page, or just start browsing AndyMark's wheels.
Unread 06-02-2012, 21:30
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Another solution might be adding a gyro to the bot so it will maintain a directional heading. (Read: drive in the direction you want it to)
