Go to Post Gee, I wonder if AndyMark has a wedding gift registry? - KathieK [more]
Unread 06-02-2012, 20:46
DuaneB's Avatar
DuaneB DuaneB is offline
FRC #1731
DuaneB is an unknown quantity at this point
Re: which sensor to use
Originally Posted by tilky View Post
we want to be able to read the angle of the robot relative to horizontal so when we go on the bridge, it will balance itself. we got it to work, but we have to reset it before and i didn't know if there was a better way
Ah, you want to measure tilt angle. The accelerometer (on the same board as the gyro, but with a separate digital interface) will work well for that. Keep in mind that the vector magnitude will be higher than 1G while the robot is moving, so you may need to compensate for that.
Unread 07-02-2012, 05:49
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
so there really is no "perfect" sensor to use?
Unread 07-02-2012, 08:08
For measuring tilt? A multi-axis accelerometer is the only reasonable choice. But no single sensor is "perfect". If you want the best possible information about the robot and its environment, you have to use many different sensors and a good algorithm for combining imprecise, noisy, and sometimes contradictory signals.
