Go to Post Engineers talk with math first, and grammar second. It is a fact of life. - Molten [more]
Unread 06-02-2012, 20:59
bs7280 bs7280 is offline
FRC #3734
bs7280 has a spectacular aura aboutbs7280 has a spectacular aura aboutbs7280 has a spectacular aura about
Attatching a belt
Hi, I am trying to attach this belt to this metal rod. I was wondering how I could go about doing so. We have access to a mill, nice drill, band saw etc... and I was thinking of milling a hole into the gear, but was not sure how big the gear would need to be. Anyways sorry if this is not enough information, any help is appreciated.
Also, for some reason the picture is upside down.
http://www.chiefdelphi.com/forums/at...d=13285798 97
Unread 15-02-2012, 23:29
smclean1969 smclean1969 is offline
FRC #3512
smclean1969 is an unknown quantity at this point
Re: Attatching a belt
You'll need sort of gear to attach to the rod. You should have some gears that came in the kit of parts that fit the belt. You'll need to drill the hole in the gear and then build a "key" (small piece of metal that slides into a groove in the gear and the rod). The key keeps the gear from slipping on the rod.
Let me know if that helps.
Unread 16-02-2012, 00:10
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Originally Posted by smclean1969 View Post
You'll need sort of pulley to attach to the rod. You should have some pulleys that came in the kit of parts that fit the belt.
FWIW, your terminology is a bit off.
There are a number of ways to secure a pulley to the shaft (provided you want a live axle). You can go with the way smclean suggested, broaching a keyway into the shaft and then using a key to hold it in place. Alternatively, you could file flats onto the shaft and use set screws to hold it in place (most pulleys come with set screws).
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 16-02-2012, 00:26
bhumudar's Avatar
bhumudar bhumudar is offline
Mentor/Programming/Electrical
AKA: Bryant Humud-Arboleda
FRC #0714 (Panthera)
bhumudar is on a distinguished road
Adding to slijjin's comment, you may also want to make sure that the pulleys that you use have a flange on them so that the belt doesn't fly off. Also you could make a set of lexan washer instead of pulleys with flanges. As for as attaching the pulleys, boring out a hole with a lathe (if available, if not a mill will work just fine.) and broaching the key slot.
P.S. McMaster sells rods with key slots already in them.
Unread 16-02-2012, 02:06
tzjin tzjin is offline
AKA: Tony Jin
FRC #0192 (Gunn Robotics Team)
tzjin has a spectacular aura abouttzjin has a spectacular aura abouttzjin has a spectacular aura about
So I'm assuming that is a 1/2" inch steel rod? The belts that came in KOP I believe are 5mm pitch HTD from Gates, so you can order Sprockets/belts from here: http://www.sdp-si.com/eStore/CoverPg...Components.htm
Be sure to try to get the ones with a flange as bhumudar mentioned, so the belt stays on better. Keyway broaches for the sprocket you can get from McMaster, and you could either get a key cutter, or just use the right sized endmill to make a slot in the shaft.
Speaking from experience, if those belts are going to have significant load on them, I would avoid relying on merely a set screw. You could try milling a flat onto your shaft, but the set screw will probably slip without it.
With a smile,
Tony
