Go to Post Think about the other teams...today your opponent, today your teammate. - Al Skierkiewicz [more]
Unread 06-02-2012, 01:05
nonamedude nonamedude is offline
FRC #1815
nonamedude is an unknown quantity at this point
Using 2 cameras
Hey guys,
Has anyone tried using two cameras? If so, how do you get the two different images , because it seems that I am only allowed to set one instance of camera.
I have set on camera to 10.xx.yy.11 and the other to 10.xx.yy.12.
I can ping both cameras so the connections should be fine.
Thanks!
Unread 06-02-2012, 07:55
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
Re: Using 2 cameras
You can try camera.getInstance(10.xx.yy.12) but I don't think it will allow two cameras.
Unread 06-02-2012, 09:48
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Using 2 cameras
That's
camera.getInstance("10.xx.yy.12");
Unread 06-02-2012, 16:44
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
Re: Using 2 cameras
You could possibly switch between the two while running, but this might be a slow process. I would suggest moving any graphical code off the classmate.
Unread 06-02-2012, 19:33
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Using 2 cameras
In the SMARTDASHBOARD we are able to use two cameras. Put both of them on seperate IPs and configure the correct IPs on the dashboard and they'll work fine.
Unread 06-02-2012, 19:55
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Re: Using 2 cameras
Are two cameras allowed on a robot?
Unread 06-02-2012, 21:20
FRC #1815
Re: Using 2 cameras
I dont think there is anything that says you cannot have 2 cameras on the robot. How do you configure the two cameras on the SMARTDASHBOARD?.
Unread 07-02-2012, 13:38
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
Re: Using 2 cameras
I have yet to find a rule that tells me that I can't have two.
Simply install the SmartDashboard and add two camera widgets instead of one and change the IP in the "Properties" menu.
