Are these servos legal?
My team needs to get a more powerful servo for our game piece, and the rules are somewhat vague on how they calculate maximum power.
[R48] states: L. an unlimited number of COTS servos with a maximum power rating of 4W each at 6V. The specs of the servos listed show the maximum current drain at 6V with no load, but is the 4W considering no load or the load that will be used? Here are the servos in question. I would appreciate your advice. 3W max with no load 2.7W max with no load |
Re: Are these servos legal?
don't forget that you can use 2 of the VEX motors... although I am not sure how you power them at this point... they will only get 5 volts from the sidecar so you would have to downgrade their rating (which is based on 7.2 volts)
they are continuous rotation and could be geared to gain advantage.. They are really good little motors.. and much more robust than any servo that fits the FIRST guidelines..and they are very similar to servos in size and shape These are not the old VEX motors ... these are new and more powerful... worth a try |
Do you think the servos I listed would be legal? |
First: It doesn't matter what I think. It matters what the inspector at your event thinks.
![]() That said I think it would be very useful for you to look at the blue box accompanying the rule, which specs out how to calculate the power for FRC applications: Quote:
Thank you sir, you are a gentleman and a scholar. Please excuse my carelessness.
(Stall Torque) X (No Load Speed) / 4 since max power output of a DC motor is at half stall torque and half free speed. |
#7
Art, what do the rules say?
#8
Yes, that is true, as I recall the curves. But, the GDC has seen fit to go straight for no-load speed and stall torque, so for this application, we don't divide by 4. If I remember correctly, there was some to-do about this last year or the year before when there wasn't a power definition at all in the rules.
#9
I'm confused about the units here. If torque is measured in oz/in and speed in rpm how does the result in watts? I'm looking a servo that has 172oz/in of torque and 72rpm no load. Is that legal?
#11
Watts have units of N-M/s (among many). Convert your torque to N-M, and your rotation rate to radians/sec, (remember that radians are dimensionless) and it all works out. By my calculation, those servos are around 9W, using FIRST's formula.
#12
Thanks! It makes sense now.
