Go to Post As engineers we should aspire to create, not destroy. If this is the case, why would we want to create machines with the sole purpose to destroy? - WakeZero [more]
Unread 06-02-2012, 21:43
Luiz12 Luiz12 is offline
FRC #4210
Luiz12 is an unknown quantity at this point
Adding motor to system please help?
Hi we're currently a rookie team with no remote idea on how to add a motor to our default code. We hooked up a simple motor to a victor and then to the system but we have absolutely no idea on how to program it.
Unread 06-02-2012, 21:54
Re: Adding motor to system please help?
What language?
LabVIEW looks like this:
Although you'd want to change "Jaguar" above to "Victor"
Found under WPI Robotics Library->Actuators->MotorControl
Unread 06-02-2012, 22:01
msulaimain's Avatar
msulaimain msulaimain is offline
AKA: Muhammad Sulaiman
FRC #3346 ([{Kamikaze Komets}])
msulaimain can only hope to improve
Send a message via AIM to msulaimain Send a message via Yahoo to msulaimain
If you are coding your robot in C++ then you can simply use the SimpleRobot example that can be accessed by going to File---New---Example---Downloadable Kernel Project---SimpleRobot---open that up and build your project. Then deploy your project to your robot. You will notice in that example that you have two drive motors connected to port 1 and 2 of your side car. You have your set up correct: Motor to jaguar (M+ and M- Side) and then from there you take wires to your Power Distribution board. You have to remember that you also have to plug in a PWM cable from your jaguar to the digital sidecar ports 1 and 2. You might have to play around with how to plug in the PWM's because sometimes you might get them flipped; just flip them over if needed and you should have two running motors. If you want to add motors then you will have each motor usually connected to a jaguar and that jaguar gets data/integer values from your code that are transmitted through the digital sidecar (blue thing). Make sure all your major components (power distribution board, side car, cRIO, etc are getting power. The dis-functioning of one of these components can cause others to cause technical difficulties which will make it harder for you. you can also read the US FIRST resources and perform a benchmark test, which helps you better understand how all the electronic components are set up.
Hope this helped.
int main()
::::::::: include=>commitment;
::::::::: int=>school name=>Asheboro::High
::::::::: int=>team name=>Kamikaze::Komets;
::::::::: Priority_Queue=>FRC Championship::2012;
::::::::: Max_Element=>Teamwork;
Unread 06-02-2012, 22:03
FRC #4210
Thank you that's exactly what I was looking for.
Unread 06-02-2012, 22:08
msulaimain's Avatar
So are you coding in C++ or Labview?
int main()
Unread 06-02-2012, 22:18
FRC #4210
This is what I ended up doing..
