Go to Post This system sucks more than our ball possession system. - IndySam [more]
Unread 02-02-2012, 19:23
DonRotolo's Avatar
Back to humble
FRC #0832
Does RS-550VC motor have a preferred rotation direction?
I did some searching but didn't find an answer. Any thoughts?
Thanks,
Don
Unread 02-02-2012, 19:40
AdamHeard's Avatar
Lead Mentor
Re: Does RS-550VC motor have a preferred rotation direction?
The motor is marked with CCW on it, which from my experience is the "preferred" direction.
Unread 02-02-2012, 21:03
KennyLives's Avatar
KennyLives KennyLives is offline
Grand Vizier of Pneumadynes
AKA: Kenneth Prouty
FRC #2122 (Team Tators)
KennyLives is an unknown quantity at this point
If it says CCW, go CCW.
No leaks. Ever.
Unread 02-02-2012, 22:44
Aren Siekmeier's Avatar
on walkabout
For those of us without access to one (in the mail), does it make it clear on the case which way that actually is? CCW when looking at the shaft end, or the back end? (I assume shaft end)
Thanks
Unread 04-02-2012, 19:12
DonRotolo's Avatar
Back to humble
FRC #0832
Yeah, I had the same question. CCW varies according to your point of view (literally). I suspect there is a standard, but I can't find it (after some searching)
Unread 04-02-2012, 20:20
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Ours are marked CCW, and one terminal is marked in red. When + is applied to red terminal, shaft spins CCW as viewed from the the front/output shaft end.
Unread 04-02-2012, 20:54
Is there any data available regarding how strong the preference effect is?
Unread 06-02-2012, 22:11
DonRotolo's Avatar
Back to humble
FRC #0832
We saw that red dot as well, and decided to wire all our motors + to red. But I still have not heard any kind of statement as to how CCW is determined (shaft end or motor end)
Eric, my experimentation showed the preference was smaller than I could measure. I loaded the motor moderately and checked the current consumption at 13 volts in both directions. They were essentially identical at about 5 A.
