Go to Post ...six-year-old Libby had dragged her by the hand over to my (M.D./Ph.D) father and said, "Daddy, this is Miss Sally. She's a doctor AND and astronaut. YOU'RE just a doctor." - Libby K [more]
Unread 06-02-2012, 22:55
cooltext cooltext is offline
FRC #0835
cooltext is an unknown quantity at this point
Distance Algorithm
Hello,
I was wondering how everyone else was finding the distance to the target using the camera? I am using the algorithm mentioned in the paper Position Determination that I have posted below. My problem is that I have to keep on changing the effective focus length depending on my distance from the target to keep measurements accurate. Does anyone know of any better methods or what I doing wrong with my current method?
thanks
Unread 06-02-2012, 23:03
Navi Navi is offline
AKA: Ivan
FRC #0840 (Aragon Robotics Team)
Navi is an unknown quantity at this point
Re: Distance Algorithm
Page 9 of the vision white paper includes an equation for calculating the distance using the pixel width, actual target width, camera view angle, and some trig.
Unread 06-02-2012, 23:56
severhale severhale is offline
FRC #4097
severhale is an unknown quantity at this point
what i did was find the height of the bounding box in pixels at different known distances. theyre inversely proportional, so the k constant is d*h. d= k/h. i got about 15000 for k but you should run a few trials. it works at angles and is accurate within at most three inches.
Unread 07-02-2012, 00:06
FRC #0835
Thank you very much for the new formula, but I was wondering, does the "k" constant stay the same when the robot is not directly in front of the target but at an angle? I was also wondering why other teams I talked to had all this crazy math and where using other images libraries like javacv?
Thanks
Unread 07-02-2012, 00:25
RoboRealm RoboRealm is offline
FRC #0443
RoboRealm is a jewel in the roughRoboRealm is a jewel in the roughRoboRealm is a jewel in the roughRoboRealm is a jewel in the rough
You may find the following educational with regards to this:
http://www.roborealm.com/tutorial/FIRST/
Yes, the height will change based on where the target is in the image. Ideally you'd measure right in the center where the distortion is the least ... but if not you'll have to apply some form of distortion to accommodate the border areas.
You should not need to change the focal length once its set. If you can't figure this out post some images with some known distances and we can help check what the issue may be.
STeven.
Unread 07-02-2012, 07:55
I think you'll find that this is the same technique as what is in the white paper, but rather than use the constants about the camera and the target and work through the relationships, this measures it as a black-box system, determines the relationship, and uses field-data to model it. When systems get complex enough, this is a very good approach. Since the math involved is just a bit of trig, it should be pretty easy to show how to compute k and to compare it to the measured value.
Greg McKaskle
Unread 07-02-2012, 19:50
FRC #0835
Okay, thanks for all the replies. but does the formula described in the white papers account for the change in angle such as moving from side to side?
Also regarding the images, i don't have access to them now. but I will post them tomorrow.
Unread 08-02-2012, 19:10
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
I initially ran into problems when testing the code used in that whitepaper because of skew moving from side to side. I changed the code to use the Y value instead of the X, so you won't run into problems with skew when moving from side to side on the field. If your robot relies on getting up close to the target you may still encounter problems with Y-axis skew, but since we're shooting balls and maintaining range, and since we have a fairly high mounted camera, we don't forsee Y skew becoming too much of a problem.
Unread 08-02-2012, 21:13
FRC #0835
Could you post your formula please? thanks
Unread 09-02-2012, 17:04
AKA: JD Russo
Here you go.
I have this as a separate VI right inside my image processing loops.
Basically what this does is:
(Actual width of the target in ft * Y Resolution of camera image) / (The processed rectangle's height in pixels) / 2 / (the tangent of the camera's FOV/2)
Be very careful with the number you're using for FOV. The spec sheets all give you the FOV in degrees, and I used radians in my labview.
EDIT: I accidentally have width*x_res writte in that image, that should be y_res if you're using the height of the rectangle
Unread 09-02-2012, 18:54
FRC #0835
Thanks for your formula. What is your average error on the measurements, and does it get worse at angles?
Unread 10-02-2012, 01:33
AKA: JD Russo
So far it's generally accurate within a few inches. Tweak the FOV number a little though, if you need. And keep in mind that FOV will change depending on if you're using the Axis 206 or the Axis M1011 camera.
Since we're using the height of the rectangle, you will notice increased error if you're driving up really close to it, since your angle will start getting funky, but the alternative is using the width, and that'll get thrown off by moving left to right at all. What we figure is since we're shooting we're not too likely to be up really close to the target anyways, so it's better to make that tradeoff.
Also, I accidentally have width*x_res writte in that image, that should be y_res if you're using the height of the rectangle.
Unread 11-02-2012, 00:48
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
You should be able to account for being under the targets by checking when width:height > 1.33 and calculating an angle from that ratio.
Unread 11-02-2012, 13:50
AKA: JD Russo
This wouldn't really work very well though unless you're directly in line with the target. Being at all to the left or the right would mean both x and y lengths are skewing, and not necessarily proportionally.
