Go to Post Each team is different, your mileage may vary. What works for your team does NOT necessarily mean it will work for others. - Andrew Schreiber [more]
Unread 06-02-2012, 23:25
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Re: Wood vs. Steel Barrier
If you're looking for a cheap solution, though I'm not sure how it compares to the real steel, what our team did was grabbed a whole bunch of pieces of angled aluminum and just put them on one vertex of our wooden barrier. Seems to work for us. Just gotta drive the robot around each time instead of going over and back.
Academic Student (Forever)
Unread 06-02-2012, 23:34
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I just went back through the field drawings to look at how the steel barrier is made, and a 4x6 steel tube might be an accurate and relatively easy to find substitute for some teams. I believe we have some 4"x6" or at least 4"x4" tube sitting on the Material Rack at my job, I will try to get some dimensions of the corner radii to compare.
-Dustin Benedict
Unread 06-02-2012, 23:42
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
That is true that team test there prototypes onto he wooden barriers and are successful but I can bet that some of those team will have a problem at their district/regional competitions. That is why I am telling my team don't rely on the success of the wooden barrier.
Unread 07-02-2012, 07:59
pfreivald's Avatar
AKA: Patrick Freivald
We covered our barrier with aluminum flashing to simulate the coefficient of friction and rounded edge in an affordable manner -- it made no difference to our drive train...
But yeah, a lesson I had to learn a half-dozen times in FIRST and am now paranoid about is this: never engineer anything so that it barely works. All values are nominal, and assume that if they're off, they'll be off in a manner disadvantageous to your robot.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
