Go to Post I thought you guys were surposed to be nerds. - Funzo [more]
Unread 07-02-2012, 09:12
vBulletin formatting escape character
I want to display a capital U inside square brackets.
But if I put a capital U inside square brackets, it gets displayed as lower case, like this: [u].
I believe this is because it is interpreted as the underline formatting command, without a matching /U command.
Is there an "escape" character in vBulletin which can be used to tell vBulletin to treat the [u] as a literal?
Unread 07-02-2012, 10:42
Re: vBulletin formatting escape character
I don't know of a specific "escape" for VBCcode, but you already know the trick for fooling vBulletin into doing formatting the way you want. Quote this response to see how I used that trick to put a bracketed uppercase [U] into it.
Unread 08-02-2012, 16:10
NullEntity's Avatar
NullEntity NullEntity is offline
AKA: Bryce
FRC #0093 (N.E.W. Apple Corps Robotics)
Team Role: Scout
NullEntity is an unknown quantity at this point
-snip-
Heh, apparently [noparse][/noparse] tags don't work. Either way, they're still really useful!
FRC Team 93 Alumni
