Go to Post So remember, we may be envious of teams who can do water jet cutting and has every possible monetary and engineering advantage, but there are many more people who are envious of every team who has a chance to compete. - Rombus [more]
Unread 07-02-2012, 09:12
vBulletin formatting escape character
I want to display a capital U inside square brackets.
But if I put a capital U inside square brackets, it gets displayed as lower case, like this: [u].
I believe this is because it is interpreted as the underline formatting command, without a matching /U command.
Is there an "escape" character in vBulletin which can be used to tell vBulletin to treat the [u] as a literal?
Unread 07-02-2012, 10:42
Re: vBulletin formatting escape character
I don't know of a specific "escape" for VBCcode, but you already know the trick for fooling vBulletin into doing formatting the way you want. Quote this response to see how I used that trick to put a bracketed uppercase [U] into it.
Unread 08-02-2012, 16:10
NullEntity's Avatar
NullEntity NullEntity is offline
AKA: Bryce
FRC #0093 (N.E.W. Apple Corps Robotics)
Team Role: Scout
NullEntity is an unknown quantity at this point
-snip-
Heh, apparently [noparse][/noparse] tags don't work. Either way, they're still really useful!
FRC Team 93 Alumni
