Go to Post I will test first 'cause you cannot learn unless you break something first! - Andy Brockway [more]
Unread 06-02-2012, 14:47
NeatTeam NeatTeam is offline
FRC #1943
NeatTeam is an unknown quantity at this point
Sonar programming
We tried to activate the Sonar sensor with this code:
http://www.mediafire.com/?kay8tn380d00syh
But unfortunately it did not work ( as in getting the distance of the object which stands infront it)
can anyone examine the code and help us understand why?
Thank you.
Unread 06-02-2012, 21:21
Re: Sonar programming
I'm not going to download a random "rar" file from a suspicious site.
Have you tried one of the "EZ1 MB1010 Sonar" LabVIEW examples?
Unread 07-02-2012, 09:58
FRC #1943
We tried both examples, analog and digital, and the indicator showed the value 0 in diffrent situations.
What may cause this problem?
Unread 07-02-2012, 10:42
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
How did you wire up the sensor?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 07-02-2012, 10:52
FRC #1943
First we wired it to Analog input and used the analog sonar example code from NI, and it showed 0.
Then we tried the digital sonar example code and we wired the Sonar to Digital I/O and it showed 0 again.
Unread 07-02-2012, 11:14
The example software is assumed to be good, so we can rule that out as a cause of your problem. That leaves configuration and wiring as the primary suspects. You did change the example's properties to connect to 10.19.43.2 instead of 10.0.0.2, right?
How exactly did you wire the sensor? Don't just say "to an analog" or "to a digital" -- give specific details on what pin or hole each wire comes from and goes to.
What is the battery voltage displayed on your Driver Station? What is the Robot Signal Light doing?
It could be that your sensor is faulty, but I've never seen one of those go bad.
Unread 08-02-2012, 11:04
FRC #1943
Ok so I've added the code in an attachment to this message and we've wired the sonar as the diagram showed in the example.
Thanks.
