Go to Post Namaste. Maybe we all one day will spend our energy trying to raise our own level to match that of the competition rather than trying to tear others down. - Rich Kressly [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 07-02-2012, 12:13
jviolette123 jviolette123 is offline
FRC #1318
jviolette123 is on a distinguished road
Re: JavaCV and OpenCV Camera Calibration with sample code
Depending on the robot's distance from the backboard, the rectangle moves up and down in the field of view. Also, depending on the tilt of the camera, the rectangle may be anywhere on a vertical line at the time of launch. We should be able to get the side to side alignment fairly close.
Some correction due to vertical placement seems to be required. Depending on the processing configuration, when this happens might change. If the cRio is doing the image work, it may be reasonable to do this correction after the fact. A coprocessor off the cRio may have enough cycles to correct up front, and simplify the geometric calculations.
