Go to Post Give us the e-mail address of these folks to send them a barrage of support letters for your students? - sanddrag [more]
Unread 06-02-2012, 22:48
gizzerd91 gizzerd91 is offline
FRC #2498
gizzerd91 is an unknown quantity at this point
SmartDashboard Camera Widget MIA
SmartDashboard's Camera widget has only shown up once in the View>Add menu in about fifteen different launches. I had it going properly last time, then I saved the layout, quit SmartDashboard, and when I reopened it the widget had gone again, and it is no longer in View>Add. The Laptop Camera Widget is also missing. It seems very arbitrary (which is frightening in programming). I've tried reinstalling, and replacing WPIJavaCV.jar with other versions, and nothing is working. I'm running this on Windows 7, bootcamp, MacBook Pro. Any suggestions would be wonderful.
Unread 07-02-2012, 00:16
Sunstroke Sunstroke is offline
Programmer
AKA: Joe Grinstead
FRC #3504 (Girls of Steel)
Sunstroke is an unknown quantity at this point
Re: SmartDashboard Camera Widget MIA
It probably has to do with how your opening the program. If you go into Program Files\SmartDashboard and double-click it there, it should work.
If you create a shortcut, or copy the SmartDashboard.jar elsewhere, or run it from shell or batch without being in the proper folder, then it might not work.
Unread 07-02-2012, 13:41
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Check to make sure that the widget is in the C:\Program Files\SmartDashboard\Extensions folder (or something like that)
Unread 07-02-2012, 15:21
FRC #2498
I was opening it through a shortcut in my start menu. Now I've opened it the traditional way, and it works! Thanks so much! You've saved me quite a bit of hair pulling.
