Go to Post I always thought a trained bio mechanical monkey wrapped in aluminum foil would be the best robot, but every year my team says "No Pete, go sit down." - BuddyB309 [more]
Unread 28-01-2012, 12:55
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Unurgent Lookover request
If its not too much trouble would anyone mind looking at my begin VI to see if anything is wrong. I did it kinda quick.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 28-01-2012, 13:03
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Keyreaper is an unknown quantity at this point
Re: Unurgent Lookover request
Look's fine to me, but what are the boxes for? Are they to separate your code?
Unread 28-01-2012, 13:07
FRC #0379
Yeah, I'm real anal about the cleanliness of my code. Its separated by sensors, motors, Joysticks, and camera.
Unread 28-01-2012, 13:47
Keyreaper's Avatar
Keyreaper
AKA: Cyrus Duong
Haha, I completely understand. May I ask how you made them though?
Unread 31-01-2012, 15:47
FRC #0379
Under the structures section (where case structures and wait structures and such are) theres a part for decorations. Its pretty nice
Unread 31-01-2012, 15:57
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
you're not really using all of those are you?
Unread 31-01-2012, 16:46
Keyreaper's Avatar
Keyreaper
AKA: Cyrus Duong
Thanks . I'm sure to learn and use these plenty much.
Unread 01-02-2012, 00:11
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
I will sometimes use decorations to document code, I do find them quite useful when looking at older code that I have forotten about. However, I usually recommend using subVIs instead. I can't look at the code right now, so I am not sure if it applies to you, but I usually separate everything into subVIs. (vision, drivetrain, funckymech, compressor, and other misc stuff. )
PS.Dear NI, please make an android VI viewer.
Mike B
Unread 01-02-2012, 10:17
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
Do you need to set the RefNum on the DIO that are plugged into the encoders? By the way i would reserve Analog 1 and 2 for gyros. those are the only slot they will work on
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 07-02-2012, 15:15
FRC #0379
@Doc534 We dont intend on a gyro but thanks for future reference. That woulda drove me insane if i tried to hook one up, it didnt work and found out that was the problem
@SuperS_5 Probably debatable. I just like having stuff in one VI so I can skim and send pics easier.
