Go to Post If you refuse to come to any compromises with your Ultimate Ascent robot design, you risk compromising everything (including your sanity). - Jared Russell [more]
Unread 04-02-2012, 11:31
cbf cbf is offline
FRC #2877
cbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nice
Image processing on the driver station laptop
Is there anything in the rules preventing us from doing our rectangle recognition on the driver station laptop rather the cRIO? Even in Hybrid mode?
Just want to make sure..
Unread 04-02-2012, 17:32
Re: Image processing on the driver station laptop
I don't see anything in the rules that prevents processing the camera image on the computer running the Driver Station.
Unread 07-02-2012, 09:24
AndyB871 AndyB871 is offline
FRC #0871
AndyB871 has a spectacular aura aboutAndyB871 has a spectacular aura aboutAndyB871 has a spectacular aura about
I think it's legal as long as you keep in mind the ports that are available on the field.
If you look at one of the more recent team updates:
The Arena
The Player Stations
Once plugged in to the Field Management System via the Ethernet cable provided, the ports that the teams will be able to access on the playing field are as follows:
– TCP 1180: This port is typically used for camera data from the cRIO to the DS when the camera is connected to port 2 on the cRIO. This port is bidirectional on the field.
– TCP 1735: SmartDashboard, bidirectional
– UDP 1130: Dashboard-to-Robot control data, directional
– UDP 1140: Robot-to-Dashboard status data, directional
– HTTP 80: Camera connected via switch on the robot, bidirectional
– HTTP 443: Camera connected via switch on the robot, bidirectional
All these ports are open on the playing field, so a team can use them as they wish if they do not employ them as outlined above (i.e. TCP 1180 can be used to pass data back and forth between the robot and the DS if the team chooses not to use the camera on port 2).
We took this to mean that we could freely use ports 1130 and 1140 to communicate data via UDP from our Dashboard to our robot and back.
In fact, this is how we're implementing our vision tracking algorithms right now. Our PC receives the Image, processes it and generates a list of targets, then that list of targets is prioritized and sent back to the robot for tracking.
-Andy
Unread 07-02-2012, 10:05
moc601 moc601 is offline
FRC #0601 (Baybots)
moc601 is an unknown quantity at this point
I've been looking for a definitive rule in the manual and other docs without success.
Are the Driver Station and Dashboard permitted to be separate laptops?
Are two laptops permitted to be used during the contest?
I'm wondering how a team would make use of the web services interface otherwise.
Unread 07-02-2012, 10:39
FRC #0601 (Baybots)
Quick followup to refine my question.
I've read about the $400 component limit that COTS laptops appear to be subject to.
The location of the laptop would be in the pit, next to the provided netbook drivers station. I seem to remember some teams having two laptops in the pit with them in our rookie year 2011.
Unread 07-02-2012, 10:41
FRC #0871
a definitive rule
|-> See my post above about port #'s I think that's pretty definitive at least on the network level.
|-> That's a good question. Maybe you should make a post at a higher level in the forum about this. I'd guess that it's okay, because you're still restricted as to what ports you can use and how the robot must be controlled, etc.
At the same time however, It's possible that the Field system is designed to disallow traffic from any IP address not 10.xx.yy.6 , in which case the second laptop (whichever one does not have the *.6) wouldn't be able to communicate, that's just me throwing a possibility out there. I've got no way to back that one up.
Edit:
You're not restricted to any number of laptops in the pit. You're only restricted on the playing field, anyone please correct me if I'm wrong there. I sure hope not.... we bought ourselves a ~$350 laptop with a nice big display to use for our DS/Dashboard
Unread 07-02-2012, 13:19
FRC #0601 (Baybots)
Edit:
You're not restricted to any number of laptops in the pit. You're only restricted on the playing field, anyone please correct me if I'm wrong there. I sure hope not.... we bought ourselves a ~$350 laptop with a nice big display to use for our DS/Dashboard[/quote]
Just to be painfully clear
So if we're in the pit with the KOP netbook and also a COTS $350 laptop we are not going to commit a foul on that basis alone.
Unread 07-02-2012, 13:21
FRC #0871
No. You're fine in the pit; I don't know if that is OK on the field though.
Unread 07-02-2012, 13:31
FRC #0601 (Baybots)
Thanks!
Unread 07-02-2012, 15:24
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
The rule about the usable ports should be last years. This year, there seems to be no restrictions.
Also note that last year's enumerated ports weren't necessarily the only ones open on the field in practice, but I wouldn't've relied on it.
Unread 07-02-2012, 16:19
mutantblond mutantblond is offline
FRC #2523
mutantblond is an unknown quantity at this point
you mean to say that we're restricted to a computer for our driver's station that cost less than $400?
Unread 07-02-2012, 16:34
FRC #2523
just answered my own question: rule 13 says that the operator console is excluded from the $3500 maximum to spend on the robot.
Unread 07-02-2012, 19:43
cbf cbf is offline
FRC #2877
Andy --
Are you using Labview? It looks to me like UDP Port 1130 is the only UDP port one can definitely depend on being open from the Driver Station to the robot. If that's the case and you're sending your own custom packet with the list of targets, how do you get the robot code to distinguish it from the normal driver station control packet?
If you're not using UDP Port 1130, how can we be sure that any other port will actually be open at the competition?
Unread 08-02-2012, 00:22
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
oh? http://frc-manual.usfirst.org/viewSingleItemMap/694
Make sure to update your manual for the team updates.
Unread 08-02-2012, 12:43
FRC #0871
cbf -
Yep, we're using labView.
The robot code doesn't have to distinguish anything here. The Driver station packets are being transmitted over a different port (1165 I believe). I'm not sure how familiar you are with networking but since they're different ports you can think of them as disjoint channels. A UDP receive on port 1130 will never see a packet from port 1165 and vice versa (sp? I never get that one right)
So in a nutshell, we just open a new socket on 1130 on the Dashboard, and pack the data and ship it out to the robot IP address; and in the Robot code We create a new socket to listen for data on 1130, and do a UDP receive followed by some error checking and an unflatten.
-Andy
