Go to Post my theory on the matter was always something along the lines of "Oh, we're all girls? What an odd thing for you to notice." - karinka13 [more]
Unread 06-02-2012, 16:16
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Question DS E09 over-reactive, won't connect
I cannot sleep now!
The E09 was imaged properly w/ all updates. We can connect to DLink. We can ping the bridge and robot, but we cannot get com/code.
Also, the software seems to recognize the old DS Radio, even though it is sitting in a box on the other side of the room. Also, when the bot is off, we still get a green light for about .5 seconds on bridge/DS Radio (cyclical).
We have no issues whatsoever with another laptop, all updates applied.
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
Unread 07-02-2012, 13:13
kws4000's Avatar
AKA: Krazy Karl
Re: DS E09 over-reactive, won't connect
Any help whatsoever? We really don't want to make a new station to put a huge computer on....or reformat the DS....
Mentoring:
Unread 07-02-2012, 13:42
Check the Classmate's IP address and netmask directly.
I assume the cRIO has been reimaged to the 2012 v43?
From what machine did you download code to the cRIO?
Does that one see everything too?
Unread 07-02-2012, 14:57
kws4000's Avatar
AKA: Krazy Karl
IP Addresses are set correctly, the new DS software sets them automatically (you can choose which adapter to modify under Setup tab->Choose NIC under the team #).
Yes it is v43.
We downloaded code from a mentor's laptop, which works w/ the bot just fine. The DS09 is the problem.
Mentoring:
Unread 07-02-2012, 16:40
Pings but no Comm/Code is usually Windows Firewall. Is it currently enabled on the machine? Try disabling and see if that resolves the issue.
Unread 07-02-2012, 16:41
Double-check that your Classmate is connecting to the robot's network. If you're on some other wireless network, you might be able to see some device at the .1 and .2 (and .4) addresses, but the DS communication status pings don't check to make sure it's the right device.
Unread 07-02-2012, 17:01
kws4000's Avatar
AKA: Krazy Karl
Alan, I was refereing to CMD ping on the DLink network, but yeah, RRRRRRuffles have RRRRidges, that worked, unblocking it on Windows Firewall works wonders!
Gee, tanks....
BTW, what would have a .4 IP? Bot is .2, I think the router is .1.
Mentoring:
Unread 07-02-2012, 22:01
Before the D-Link combination Access Point/Bridge made it unnecesasry, the old blue Linksys router was used to create the wireless network for the robot's black bridge to connect to. That router was configured at the .4 address.
