Go to Post Anyone who makes a minibot that poots out another minibot that blows the wall apart deserves to have it displayed in the Smithsonian. - Koko Ed [more]
  #121   Spotlight this post!
Unread 07-02-2012, 15:37
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: 2nd Most Awaited Q and A Answer?
Originally Posted by jason701802 View Post
I would expect this to be handled similarly to 2010, where it was the responsibility of the inspectors to ensure that a ball could not get more than 3in into the frame, so that the refs only have to look for obvious violations of the rule, like deploying two completely different appendages at the same time.
Inspectors (Lead inspectors, at least) should also consider when to let the Head Ref know that there is something to look out for-- "Team XXX has an appendage that is mechanically able to swing sideways into the corner which would be illegal, but they claim the SW (or the driver) will prevent it from happening. Keep an eye out for it." Or something like that...
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
  #122   Spotlight this post!
Unread 07-02-2012, 16:16
RDX1466's Avatar
RDX1466 RDX1466 is offline
Honey Badger
AKA: Matt
FRC #1466 (Webb Robotics)
Team Role: Webmaster
RDX1466 is on a distinguished road
Our design uses a "clam-shell" style appendage that will come together to drop a ball for the short-range shooter.
It is my understanding that as long as the frame perimeter is only crossed once, the appendage can fork off into multiple appendages (say 7" out for example).
Would a clam-shell design that is hinged WITHIN the frame perimeter be considered two appendages, even though it is mechanically contiguous?
  #123   Spotlight this post!
Unread 07-02-2012, 16:53
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
You could always ask the GDC, but would think they would indicate that they are not able to advise on any design. Current answers, regarding this topic, from the GDC on the Q&A forum would indicate that because the hinge is within the frame perimeter, this design would be illegal.
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
  #124   Spotlight this post!
Unread 07-02-2012, 16:59
SteveGPage's Avatar
AKA: Steve
An update:
[G21]Robots may extend one appendage up to 14 in. beyond a single edge of their frame perimeter at any time.
Violation: Foul for exceeding size allotments; Technical-Foul for continuous or repeated violations.
These appendages are intended for use in manipulating Basketballs and/or Bridges. A Robot may have multiple extension devices onboard, but only one may be deployed at a given time.
All portions of an appendage that are outside the Frame Perimeter must be contiguous with each other. Very brief violations of the contiguity requirement as a single appendage is being extended or retracted will not be penalized.
  #125   Spotlight this post!
Unread 07-02-2012, 17:00
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
I was thinking the same thing. Maybe if there was a system (possibly integrated into the FMS, I don't know enough about the systems they use) were inspectors in enter quick notes about teams that the refs would see when the teams came on the field.
Originally Posted by Siri View Post
Perhaps what they need to do is define it as "after deployment, or when it intentionally comes in contact with a Court element (whichever comes first)".
This seems like the simplest and best solution. Possibly modifying it to be "The contiguous part of an appendage must be outside the frame perimeter before the appendage may interact with any game/field element(s)"
EDIT: I guess this works too:
This would allow rollers with whips as long the whips start within the frame perimeter and the solid part of the roller is pushed to the frame perimeter before it is used.
Jason
  #126   Spotlight this post!
Unread 07-02-2012, 17:01
From today's update!
[G21]
Yeah!
John Vriezen
  #127   Spotlight this post!
Unread 07-02-2012, 17:10
Bob Steele's Avatar
AKA: Bob Steele
I can now rest better...Common sense has prevailed...
Hurrah!!
  #128   Spotlight this post!
Unread 07-02-2012, 17:12
mott's Avatar
mott mott is offline
AKA: Mike Ott
FRC #1619 (Up-A-Creek Robotics)
mott is on a distinguished road
Amen to that!!!
  #129   Spotlight this post!
Unread 07-02-2012, 17:14
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Hurrah!!
X2!!!!
  #130   Spotlight this post!
Unread 07-02-2012, 17:25
Bob Steele's Avatar
AKA: Bob Steele
By the way....PLEASE Don't start arguing about what "Very Brief" means...
:0)
  #131   Spotlight this post!
Unread 07-02-2012, 17:43
SteveGPage's Avatar
AKA: Steve
Not to squash the feelings of jubilation after this latest update, but it does bring into question another issue. In a couple of recent Q&A answers:
Game - The Game » Robot Actions » G21
Q. Can appendages (one at a time) be used for purposes other than manipulating Basketballs and/or Bridges?
FRC3005 2012-01-11
A. Yes, as long as no other rules are violated.
Game - The Game » Robot-Robot Interaction
Q. Can a robot grab onto another robot, of the same team in a nondestructive manner, in order to help balance on the bridge?
FRC0122 2012-01-21
A. Yes, provided Game rules are not broken, specifically [G26] and [G27].
With this new update, "These appendages are intended for use in manipulating Basketballs and/or Bridges" - those answers can be called into question. Can you design the appendage for a use different than manipulating the Basketballs or Bridges, such as to grab onto your alliance partner while attempting to balance the bridge?
If I had an appendage whose primary function is other than for manipulating the Basketballs or Bridges, I would ask for clarification from the GDC as soon possible.
  #132   Spotlight this post!
Unread 07-02-2012, 18:01
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
That question was already asked several weeks ago:
Q. Can appendages (one at a time) be used for purposes other than manipulating Basketballs and/or Bridges? FRC3005 2012-01-11
Art Dutra IV
世上无难事,只怕有心人.
  #133   Spotlight this post!
Unread 07-02-2012, 18:07
SteveGPage's Avatar
AKA: Steve
As we both quoted, the answer indicates that it CAN be used for other purposes, but my concern is if it is designed ONLY for another purpose, then I might want to look for clarification.
  #134   Spotlight this post!
Unread 07-02-2012, 18:43
Tuba4 Tuba4 is offline
AKA: Tom Albert
FRC #0063 (The Red Barons)
Tuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant future
An update:
This is good news. It should put the question to rest for most kinds of appendages. I am not certain how it will impact ball harvesters using a rotating drum with surgical tubing whips, which seem to be a common choice. I think they may still not be legal. Clearly if the drum does not extend beyond the frame perimeter and only the "whips" do, that would not be legal. And if your drum was able to move and extend, then it would need to retract in order to extend a bridge appendage.
  #135   Spotlight this post!
Unread 07-02-2012, 19:02
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
I love common sense.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
