Go to Post “There are two ways to compete, one is to drag your opponent down, the other is to raise the bar and excel. Which do you think is more beneficial to you in the long run?” -- John Abele - Candice.E [more]
Unread 07-02-2012, 18:39
Wildcats1378 Wildcats1378 is offline
Wildcats1378 is an unknown quantity at this point
Compressor issues, and motor issues
Hey guys,
I've been trying to get this compressor to work for a while now and i had it working and its stopped again.
Its a bit strange, but the spike will go on/off pretty rapidly. I noticed that the fuse for the sidecar was not Plugged in, and when i plugged it in the compressor just went to a static light. I've enabled the compressor loop in periodic tasks, and just did "open - start - -->" in begin to start it. Any help is greatly appreciated.
Ive also been trying to make a motor controlled by the throttle on the joystick. Ive simply plugged the Axis 3 into the MotorSet vi (output) but it didnt work. Any suggestions?
Thanks very much
Unread 08-02-2012, 05:44
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Re: Compressor issues, and motor issues
make sure that all of the RefNums are correct. Under periodic, compressor is called "The name". Also, under begin, do open->Start->set refnum
