Go to Post Now the real question is where are corn dogs located on that list? That is truly all that matters. - Thad House [more]
Unread 07-02-2012, 19:24
Matthew Wang Matthew Wang is offline
Project Manager, Vice-President
FRC #3588 (The Talon)
Matthew Wang is an unknown quantity at this point
Does the Solenoid From the KOP have a Manual Switch?
Does the solenoid from the KOP (the Festo one) have a manual switch to extend and retract the pnumatic actuator on it? I know some solenoids do, but we can't seem to find any buttons on the KOP Solenoid that would do so. I'm not sure if there's any difference, but we acquired our solenoid from the KOP last year.
Thanks!
Competition Record
2011 Logomotion
  • Seattle Regional
  • St. Louis Championships
2012 Rebound Rumble
2013 Ultimate Ascent
Awards Record
2011 Logomotion
  • Rookie All-Star @ Seattle Regional
2012 Rebound Rumble
  • Team Spirit @ Seattle Regional
Unread 07-02-2012, 20:15
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Does the Solenoid From the KOP have a Manual Switch?
There is a small blue button on each side of the solenoid, on the top where you have two ports. They look like a flathead screwdriver should go into them.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 07-02-2012, 22:08
Or a pen point.
Unread 07-02-2012, 22:29
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Take a look at this animation for some clues on how this fancy device works. Good luck with your air controllers.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 08-02-2012, 07:42
The Festo valves in the Kit need a small screwdriver and twist to manually fire. You have to do each side of the double solenoid individually.
Unread 08-02-2012, 09:26
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Mark, they can also be pushed in with a pointed object.
Unread 08-02-2012, 09:32
I just didn't lean hard enough.
It seems to be that pushing is momentary, while twisting is permanent.
Be aware that twisting to make it set permanent must be undone before trying it electronically.
Response will vary depending on how the corresponding side of the double solenoid is currently set.
