Go to Post 2015 never happened - Chris is me [more]
Unread 07-02-2012, 09:21
normpear2 normpear2 is offline
Team Programming/Electrical Co-Lead
FRC #2603 (Highland FIRST Robotics Team #2603)
normpear2 is an unknown quantity at this point
Send a message via AIM to normpear2 Send a message via MSN to normpear2 Send a message via Yahoo to normpear2
Camera Problems
I have the Older Axis 206 Camera, and I used the new FRC Camera Setup to set the FRC account and change the IP to run through the router.
I did this twice, both times, after a reboot of the C-rio and camera at the same time, both times the camera stopped working and I needed to reuse the Camera Setup tool. The 3rd time, the Camera stopped again. I tried the tool for no luck. I attempted to use the Factory Reset button to reset the IP and settings to the default 192.168.0.90, only to find: 1.) the Camera IP remained as 10.26.3.11; 2.) The camera was only abled to be pinged @ 10.26.3.11; 3.) The camera webpage was inaccessable from either 192.168.0.90 or 10.26.3.11 both times the Laptop IPs used to 192.168.0.72 and 10.26.3.72 for each attempt. Both times the Camera was either pinging randomly between 2-50 ms (This was directly connected to the laptop) or Received Destination Host Not Found Errors.
Any ideas? Camera bricked or is there a way to fix this? I have confirmed the following the reset instructions that the Reset button isn't resetting the camera to defaults.
Unread 07-02-2012, 09:48
Re: Camera Problems
I think the original issues was caused by the bug in the camera config tool. The settings it applied to the camera were inconsistent wrt networking and on boot up, the camera would decide to factory reset.
As for the unresponsive camera, have you tried unplugging it, pressing and holding the reset button, then insert the power and continue holding the button until the LED ring on the camera goes amber -- potentially even longer? I've never seen one that wouldn't factory reset. If this is not successful, you may need to visit the Axis site and look for firmware downloads and follow the directions associated with putting new FW on the camera.
Greg McKaskle
Unread 07-02-2012, 20:17
dakaufma dakaufma is offline
AKA: David Kaufman
FRC #0449 (Blair Robot Project)
dakaufma is an unknown quantity at this point
Re: Camera Problems
I've had to reset the camera twice before it actually reset; perhaps it's just easy to think you've reset it when you haven't. Try the factory reset a few more times before you give up on it.
As for the Imaging tool, your problems make it sound like you are using the old one. Is it possible that you've downloaded the new tool but are accidentally running the old tool?
Unread 09-02-2012, 14:30
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Camera Problems
Here is the process that Greg posted in a different thread. We had the same problem as you and this fixed it. I bet that the updated Camera Config Tool fixes this problem too but this worked for us:
Originally Posted by Greg McKaskle View Post
I believe it was. I'll reset it and test again.
OK. I reset and ran the tool on the 206. When I power cycle the camera, it never turns the LEDs green. I suspect this means it factory reset on power up. My normal advice would be to make sure the mounting of the camera doesn't hit the reset button, but since it is my advice, ...
Anyway, I agree that something seems rotten with the new camera config utility. I'll see if I have the source. In the meantime, if you are seeing this issue, I'd recommend hand configuring
1. Factory reset the camera.
2. Set computer IP to 192.168.0.xx where xx is not 90.
3. Launch web browser and enter 192.168.0.90 into the URL.
4. The camera will ask you to set the root password. Use admin or whatever you like.
5. It will ask you to log into the camera (root:admin).
6. Click on the Setup tab.
7. Click on the Users link on the left.
8. Add (FRC:FRC) as an administrator.
9. Switch to the TCP link and set the IP to manual 10.te.am.11 and I set the router to 10.te.am.01.
10. Change computer IP back to 10.te.am.xx and go about your way.
Thanks for the specifics in reproducing this. I'll look into it a bit or get the author to look into it on Monday.
Greg McKaskle
