Re: Wheel Positioning
High traction in the center. If you're not using all traction wheels, then you'll ALWAYS* want your traction wheels in the center.
*Not always always, but most of the time always |
normally i would say center $@#$@#$@# well. but not so sure this year.
friction wheels might be very neccisary for going onto the ramp. and if they are in center they may lose contact with the ground when mounting the ramp; omnis might not giving you enough traction to get on the ramp (well). |
I see two things that should work well for you:
1. High traction wheels in the center. Other wheels on the outside. Using the "medium" traction wheels on the outsides will give you more traction. 2. Use high traction wheels for the center, and either the front or the back. Then, use the omni's or these "medium" traction wheels for the other set. This should make you a "rocker" drive train, but with one balanced, level potion instead of two "rocked" or "tipped" positions like a normal rocker drive train. Best of luck -Jeff |
Thanks for the feedback everyone. We ended up adding a second set of high-traction wheels in place of the medium traction wheels, and leaving the omnis in place (which don't have any drive power). I was a bit suprised to see us turning so nicely with all that traction, but it seems like we're going to stick with this setup (plus it took more than 2 hours two change out the wheels, so nobody really wants to experiment anymore
