Go to Post The GDC has spoken, we have listened and will follow their ruling. - ChuckDickerson [more]
Unread 26-01-2012, 21:27
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
Counter & DIO not working every time
Hey guys,
We're using the Counter class of the WPI Library in LabVIEW to count the rising edges of a proximity sensor (simple DIO through the Sidecar) in its semi-period mode.
Our procedure at the beginning is to turn on the cRIO and run Robot Main/deploy the whole robot project. This first time, our Counter does not register anything without any errors). However, if the robot project is re-deployed in the same way without any changes to the code, the counter works perfectly.
The raw DIO data works perfectly fine (we get raw feedback from our sensor regardless of the number of times it has been deployed) but the Counter appears to be unreliable.
Can anyone give any advice on this? Is this a problem others have replicated?
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 02-02-2012, 21:28
kenavt's Avatar
AKA: Colin S
Re: Counter & DIO not working every time
Consider this a formal bump. This issue is starting to cripple us, and getting a bit worse in that it takes more deployments to get the system to work. Any help would be appreciated.
We're hoping to test the exact same code with a different cRIO on Saturday.
Unread 02-02-2012, 22:35
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
I don't know anything about this specific issue, but this seems similar to the issue we had last year with Encoders (which internally use Counters for 1x or 2x). We could not get Rate from half of the counters(1x/2x) or encoders(4x) on the first boot, but could get Distance.
The workaround (for the entire 2011 season) was to only use half of the Encoders, since half of the FPGA counter and encoder(4x) modules had issues. We created dummy encoders in a specific order to force LV to allocate the counters in a specific order, and it worked, then jhersh released a workaround which marked the bad encoders/counters as already allocated in the WPIlib, so it would not use them.
Try creating two in order (by wiring a wire between the errors on the Opens so it forces them to execute in order) and seeing if both or only one has this issue.
Kettering Motorsports
Unread 06-02-2012, 21:42
kenavt's Avatar
AKA: Colin S
Our current status is that we've added in error wires to control the data flow in the Begin.vi when initializing the counters. We have four Counters being initialized in the order of Real - Dummy - Real - Dummy. The Counters now appear to be working properly when perma-deployed and when temporarily deployed. We are now having trouble using Counter data in the Teleop.vi, but that appears to be an issue with our PID loops, not the Counter class itself.
Palardy, could you elaborate on the issue you had last year and the workaround? Is that what we implemented?
Unread 06-02-2012, 22:57
apalrd's Avatar
More Torque!
VRC #3333
That's what we did last year. I couldn't remember if the first one was dummy or real, but they alternated (at least the first few did, one of the last ones seemed random).
What issue are you having with the data?
Unread 07-02-2012, 21:31
kenavt's Avatar
AKA: Colin S
Hmmm, alright.
Our current issue now is discrepancies between how the LabVIEW code works when it's temporarily deployed and permanently deployed. We have integers that are outputs from a NI default PID node. The inputs are valid doubles or clusters of doubles. We have feedback going to the User Message area in the Driver Station that reports the integers as strings correctly (in Teleop.vi) when temporarily deployed, but not when the program is permanently deployed. Then, "NaN" is displayed instead. Have you had this issue either?
Unread 08-02-2012, 08:02
apalrd's Avatar
More Torque!
VRC #3333
Have you probed the wire to see if it actually is NaN? Try probing up to the source of the NaN.
I usually use NaN in my code to indicate fatal error conditions. It's possible something has an NaN error.
Unread 08-02-2012, 16:10
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Can you post a simplified version of your code that exhibits the problem, along with instructions on how to reproduce the problem? If so, I can try it on my test system.
Doug Norman
Unread 19-02-2012, 23:45
kenavt's Avatar
AKA: Colin S
Our head programmer intended to post himself on this thread with code, but he never got around to it, and the issue appeared to resolve itself (No, we don't know how).
I don't have code on hand (will attach in future post when I can get at it). I want to post screenshots of the apparent solution if anyone else in the future has this issue.
