Go to Post ...I tried to pump it up to the 47 inches. I stopped around 42 inches, than tried getting it through a 36" door. It got stuck, I proceeded to dropkick the thing in front of my team and a girl I had gone out with the previous Fri. It didn't move, I hit the floor. Ouch, my pride. - ChrisMcK2186 [more]
Unread 07-02-2012, 21:56
Johnny_5's Avatar
Johnny_5 Johnny_5 is offline
Whose cooking motor?
AKA: Isaac
FRC #3484 (Short Circuit)
Johnny_5 has a spectacular aura aboutJohnny_5 has a spectacular aura about
3484 Teaser
Here is a link to our launcher, for some reason I can't attach photo's to this post.
Check it out, not a normal thing you will see on the field!
http://www.chiefdelphi.com/media/photos/37362
Unread 07-02-2012, 22:00
Andrew Lawrence
Posts: n/a
Re: 3484 Teaser
How does it work?
What is your reasoning for making it work that way?
Why did you design it this way?
What competitive advantage do you think you'll get from this design?
I love it, but I always have to ask those questions. Also, always need to ask this:
How can you make it better?
Unread 07-02-2012, 22:01
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
Re: 3484 Teaser
Is that aluminum?
What size bolts did you use?
where is the power source?
cole?
Unread 07-02-2012, 23:28
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: 3484 Teaser
Centrifugal launcher?
Unread 08-02-2012, 04:31
FenixPheonix FenixPheonix is offline
FRC #0751 (Barn2Robotics)
Team Role: CAD
FenixPheonix is on a distinguished road
Re: 3484 Teaser
Interesting. I would guess some sort of crossbow, using the pivot arms to stretch surgical tubing or something.
What framing system is this? It looks like 30x30 bosch, but I don't recognize the gussets. The pivot connectors also look a little off.
Unread 08-02-2012, 15:58
Johnny_5's Avatar
AKA: Isaac
Re: 3484 Teaser
@SuperNerd256
It works by a motor pulling back a cord system that in turn pulls back the trolley that is attached to the spring arms. On the spring arms there are spring mounts that go to the 2 pieces that stick out in the front of the robot. We can whatever springs we like on there to our specs. On the drive system for the launcher there is an electromagnetic clutch where the cable collects. We engage the clutch and free spin the motor to launch. An encoder on the drive system along with reed switches up and down the launch rail tell us where the trolley is at all times.
The reason we designed it this way is because we noticed how much change there are in the balls. Friction type launchers will just throw balls all over the place, I mean if you look at the baseball, tennis ball, basketball launchers the goal is speed at the end of the launch, not dead on accuracy. With this concept the balls are never collapsed or compacted.
We designed it this way for accuracy and repeatability. Accuracy is the easy part, just getting it to point and shoot. But the problem will be repeating the same results hundreds and hundreds of times, and all teams are facing this.
Competitive advantage (I'm going to let a secret slip here too) is repeatability and accuracy, and for that we were able to lower the requirements for some other systems. For instance we are loading from the feeder slot because we can afford to. The major point with this design is repeatability, and power, we plan to shoot from the half court line. Last year we were one of the most powerful robots out there in terms of drive train.
Our one plan right now is to finish the whole system before we start making changes or improve parts of it. But right now I see a problem with the ball carriage system which isn't on there yet.
@372_lives_on
We are using extruded aluminum on the robot, they are M8 fasteners
@FenixPheonix
It is a sort of crossbow, partly because how many devices for hunting do you see that use a friction launching system. However it isn't surgical tubing, not repeatable enough, so we are using springs.
The framing system is an Item North America product. It is a 40x40 Profile 8 building set. They sell all of the pivot connectors and gussets you see there, they also offer it in 3 different lines. Economy, Light, and standard for different requirements.
