Go to Post This [Coach badge] means no-touchy the controllers. Even to save them from certain doom. - Kevin Sevcik [more]
Unread 07-02-2012, 23:39
Luiz12 Luiz12 is offline
FRC #4210
Luiz12 is an unknown quantity at this point
using Vex motor
So basically I programmed the controls to run a victor type motor on a PWM port 4. And well if I plug in a victor motor it will function properly but when I plug in the vex motor it does nothing. I'm using a vex 2 wire motor with a motor controller cable with a female to female adapter cable.
Unread 08-02-2012, 01:35
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
Re: using Vex motor
Many thread have already been over this, but you need to you use the motor controller that comes with the vex motor. Plug it into the same port and next to it put a jumper. That jumper provides ~6v of power for the motor to work. Now far as programming I could not tell you how to program it. I'm sure the other 10 threads will tell you.
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 08-02-2012, 04:05
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: using Vex motor
You should be programming it right, the common mistake is just that the jumper is not in place to provide power to the motor controller. You would connect it just like a servo since the motor needs to be powered by the Sidecar.
