Go to Post Getting that degree is the reason for going to college. Failing out of school because you mentored isn't really a good reason. - [more]
Unread 07-02-2012, 23:59
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: How much does your robot weigh?
We are at 70 lbs in cad.
And that is without electronics and pneumatic [no compressor].
We should be just about 110 fully loaded.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
(Read in a sarcastic, monotone voice)
Yes, It's not like I bolded anything.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 08-02-2012, 00:04
Andrew Lawrence
Posts: n/a
I know! I just knew that if I mentioned something totally different, than someone would catch onto it.
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
Yes. 256 is going to have their battery mounted on the very top of their robot this year. :|
o.O i JUST DECIDED THE SAME THING 5 MINUTES AGO. WE AR HAVING ALL ELCTRONICS ON OUR SHOOTER TOWWER WITH THE BATTERY LOCATED DIRECTLY ABOVE THES SHOOTER!!!!!!1!!!1!!
cole?
Unread 08-02-2012, 00:05
JosephC's Avatar
I think someone needs less mountain dew and more sleep
Referee: 2015 - ?
Unread 08-02-2012, 00:09
Andrew Lawrence
Posts: n/a
BEST. THING. EVER! That saying just made my day!
Unread 08-02-2012, 00:15
JosephC's Avatar
That HAS to go in my signature!
On an unrelated note, I probably just described myself. Haven't gone on an all caps rage yet, but there's always time...
Referee: 2015 - ?
Unread 08-02-2012, 00:23
Andrew Lawrence
Posts: n/a
Thanks!
Unread 08-02-2012, 00:47
Team Role: Mascot
no really we don't want our "shooter" flying off the robot and we need the battery weight to hold it down.
cole?
Unread 08-02-2012, 01:25
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
The first iteration weighs approximately 120 pounds, without any weight reduction techniques. This is very strange for our team
CAD is a lifesaver.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 08-02-2012, 02:10
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Drive itself is 86 lb, with the electronics board, about 90 lb.
Unread 08-02-2012, 02:48
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
In CAD? 93 lbs + chain and fasteners (should bring it up to about 110).
In real life? About 20. (Yeah we're behind )
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 08-02-2012, 09:49
Andrew Lawrence
Posts: n/a
On the bright side, you may be the lightest robot at SVR! How easy will it be to balance the bridge with three robots when one of them weighs 1/6th of the maximum weight!
Unread 08-02-2012, 10:07
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
As of last night, with all major components mounted, approximately 107lbs.
BTW batteries weigh ~13lbs, weight adds up with 6awg wire on the battery though.
Unread 08-02-2012, 15:14
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
We are looking at around 70-80 completely finished with no reduction techniques. and a note to everyone using autodesk- it does have CAD weight issues that can be as high as 20-30 lbs off. Solidworks is around 1-2 lbs off. But in autodesk try to manually enter each parts' weight for a better estimate
