Go to Post you are going to gear that down right? Otherwise your robot will take about 10 minutes to reach its top speed of mach 2.6. - M. Hicken [more]
Unread 07-02-2012, 21:46
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
Run with solenoids from a spike
I found a FESTO VPLE18-M5H-4/2-1/4 pneumatics valve in our pneumatics box, its the same one we used on our 2008 robot, it is ran by a spike. We are only using one solenoid on our robot, can we still use this on our 2012 robot?
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 07-02-2012, 21:51
Re: Run with solenoids from a spike
Eric,
This appears to be a legal valve and it can be powered by either the solenoid module in the Crio or a Spike. Please remember that you have to account for the cost under the BOM and all other robot rules apply.
Unread 07-02-2012, 22:41
Doc543's Avatar
AKA: Eric
I have a safety concern with it also, when the voltage is 0, like it is on disabled it will still put air from the system into the piston. So if the robot is turned off it will (if it was on) move the piston. The safest way should just vent all sides to the atmosphere.
Unread 08-02-2012, 00:42
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Yes, that is what "stand clear" stickers are for. This is normal and (sometimes) desirable if you want the robot to continue to move after the match ends.
Unread 08-02-2012, 07:22
Eric,
When designing pneumatics one should plan that nothing moves when the robot is enabled and pressure in the pneumatic system starts to build. It is relatively easy to do this if you think about it.
Unread 08-02-2012, 18:06
Doc543's Avatar
AKA: Eric
We could set the default position to up, but if it is down when the round ends, it will move back up when it is disabled or powered off.
I have an idea, if I put another solenoid just off the working end that will release all the air out of the working end the robot is disabled or shut off. It would plug up the storage so we wont lose our storage between rounds or demos.
There is a rule that says we cant use multiple solenoids to run a single cylinder, do you think that they would consider that against the rules?
Unread 09-02-2012, 07:32
Eric,
Not exactly sure what you are asking. The rule about multiple solenoids on a single cylinder is to prevent higher than normal airflow into the cylinder.
Unread 09-02-2012, 15:57
Doc543's Avatar
AKA: Eric
Basically what I want to do, is have an extra solenoid on the robot that will release all the air on the working end of the system if the robot is disabled.
Unread 09-02-2012, 16:14
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Check out the information sheet here: http://team358.org/files/pneumatic/F...structions.pdf
This is a 1 way valve, so it has a default position when it is not actively switched. So if the piston is connected to the valve as described in the operation table on that page, when the valve is not activated, the default position of the piston is with the rod retracted. You can use that to your advantage in your design - when the match is over and the robot is disabled, the rod will retract.
I think this type of behaviour is what you want. Now you need to work that into your design for use of the piston.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 09-02-2012, 23:23
Doc543's Avatar
AKA: Eric
Sorry if I am confusing some of you it took about 15 minutes to explain to one our mentors what I wanted to do. I did find a solution to my problem though, so hopefully I can get some sleep tonight.
This setup will release all the air out of the working side of the pneumatics system while keeping the storage held if the robot is disabled, emergency stopped, or powered off.
This setup is using the FESTO VPLE18-M5H-4/2-1/4 pneumatics valve (http://team358.org/files/pneumatic/F...structions.pdf)
On the default state 1 will go to 2 and 3 will go to 4, when it is on 1 will go to 4 and 2 will go to 3. I connected 1 to the air source, 2 to a plug, 3 is open to the atmosphere, 4 is to the working end.
Unread 13-02-2012, 07:33
Eric,
From what you describe, I am not sure that there is a legal method to achieve this result. If you open the working pressure side of the regulator, you will also release all stored pressure on the robot. I would rather your robot do nothing when disabled then for it to potentially move when disabled. You will be cycling through enabled/disabled throughout the competition season. During at least one of those times, an inspector will be standing near your robot checking over systems during a "power on" test where you will be asked to enable your robot. When the systems test is complete you will be asked to disable the robot and then power down while the inspector checks other power off functions. I don't want an inspector surprised or hurt by the sudden release of air or the movement of parts.
Unread 13-02-2012, 11:19
Doc543's Avatar
AKA: Eric
The way I designed the system it will bleed all the air of the working end to the atmosphere, but I also got it to not release the air from the storage end. When it bleeds all the air form the working end it will release all the air in the cylinders form the robot so it would have no compressed air in it when the robot is off.
Unread 13-02-2012, 11:24
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
That's the thing though, in the process of releasing the pressure, whether it be from the High or Low(working) pressure side, chances are, parts will be moving as the cylinders lose pressure.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 13-02-2012, 15:57
Doc543's Avatar
AKA: Eric
at least when they move they wont have 60psi behind them, they would just float.
Unread 15-02-2012, 07:27
Gravity is irrepressible!
