Go to Post Continuous improvement turns good to great. Continuous tinkering can lead to inconsistent behavior and headaches. - IKE [more]
Unread 08-02-2012, 08:11
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
FP Motors, a sad moment
So we would like to mount a FP motor to drive a gear box, but it would need to have a pinion that could work with the CIMple box gear box. To our display we realized today that it will need another pinion. Any idea how to remove the one on there, and put on one that will work with that shaft size?
Unread 08-02-2012, 08:17
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: FP Motors, a sad moment
This thread has some excellent methods: http://www.chiefdelphi.com/forums/sh...ight=FP+Pinion
-Dustin Benedict
Unread 08-02-2012, 08:50
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
One of these guys should work. You can buy them at your local hobby shop. Just ask for a 550 sized motor pinion puller.
Unread 08-02-2012, 10:24
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
My experience with the FP pinions is that they're a lot more difficult to remove than you'd expect. The pretty much laugh at miniature gear pullers, if you can even fit the gear puller over the gear.
We usually assume we're never going to use the gear again, and squish it. They're made of soft-ish metal, so if you squish it REAL hard in a vise, turn it 90 deg, and squish again, you can usually deform the hole around the shaft and it'll loosen up and slide off. I've also heard of teams using nut splitters, but we ruined a nut splitter trying that, so I'm not so sure about that.
Unread 08-02-2012, 10:34
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
http://www.hobbyking.com/hobbyking/s...oval_Tool.html
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 08-02-2012, 12:03
matteo2171's Avatar
matteo2171 matteo2171 is offline
AKA: Matteo Rini
FRC #2171 (Robodogs)
Team Role: Driver
matteo2171 is an unknown quantity at this point
My team also had to figure out how to remove the pinions so we could put on the one for the AM Planetary Gearbox after failing several times with various other methods we just cut it off with a dremmel, you just want to be careful so that you dont cut the shaft or the motor
Unread 08-02-2012, 12:16
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
We found a very simple way to do it. We took a 1 x 1 x 1/8" angle and cut a slot in it, just wide enough to fit around the axle, under the pinion. The upturned leg of the angle is strong enough to resist the forces needed.
The we pressed on the shaft with a small arbor press and the pinion hopped right off.
If this isn't clear contact me personally and I will send a photo.
Unread 08-02-2012, 12:54
Mr. Flaiz Mr. Flaiz is offline
FRC #0514
Mr. Flaiz is an unknown quantity at this point
These are really easy to remove. As the person above stated use a piece of angle to support the gear and push the pinion out. We use 2 pieces of angle so we don't need to slot it then place the angle over an open vise and drive the pinion out with a smaller pin.
