Go to Post The thought of destroying any robot is just......depressing :( - Richard McClellan [more]
Unread 08-02-2012, 15:05
agartner01 agartner01 is offline
Captain + Control Sys & Design
FRC #4174
agartner01 is an unknown quantity at this point
Re: Live C++ help
Originally Posted by mikets View Post
If you have a voltmeter, you can check the voltage between the +5 and the GND pins on the accelerometer to make sure it indeed gets power (in case you have bad connector). If you have an oscilloscope, check the SCK line, it should give you a train of square wave. No matter what color wires you hook it up, make sure +5 is connected to +5, Gnd to Gnd, SCL to SCL and SDA to SDA. By convention, +5 should be RED and Gnd should be BLACK.
Alright, I took the voltmeter to the pins on the accelermoneter and it did get power. I'll have to ask around to see if anyone has an oscilloscope.
Unread 08-02-2012, 16:38
FRC #4174
Re: Live C++ help
Alright, I'm going to try and use the gyro for what I need instead. I have no idea what up with the accelerometer
Unread 08-02-2012, 16:42
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Live C++ help
Did you try what Bob649 suggested? I think we connected to the other set of pins, not the one you showed in your picture.
Unread 08-02-2012, 16:49
FRC #4174
Re: Live C++ help
yeah... nothing changed. I did change the port to 2 in the code.
Unread 08-02-2012, 17:06
mikets's Avatar
Software Engineer
Re: Live C++ help
What do you mean by that? Are you saying you specified module number 2 when instantiating the ADXL345 class? If so, do you really have two Digital modules in your cRIO and what slots are they plugged into?
Unread 08-02-2012, 17:08
FRC #4174
Re: Live C++ help
Bold = change.
accelerometer = new ADXL345_I2C(2, ADXL345_I2C::kRange_2G);
Unread 08-02-2012, 17:11
FRC #4174
Re: Live C++ help
I thought thats what you did to tell the crio which port the sensor was on (1= left sides, 2 = right side). How else would it know where it was?
Unread 08-02-2012, 17:14
mikets's Avatar
Software Engineer
Re: Live C++ help
No, the left side and the right side set of pins are not modules. The '2' you specified is the "module number". That's the cRIO modules. I2C is a bus, you don't need to differentiate it.
Unread 08-02-2012, 17:23
FRC #4174
Re: Live C++ help
nope still nothing
Unread 09-02-2012, 08:41
msulaimain's Avatar
msulaimain msulaimain is offline
AKA: Muhammad Sulaiman
FRC #3346 ([{Kamikaze Komets}])
msulaimain can only hope to improve
Send a message via AIM to msulaimain Send a message via Yahoo to msulaimain
Re: Live C++ help
Hi, I have the following error on my driver station when I enable teleop:
ERROR: A timeout has been exceeded: RobotDrive...Output not updated often enough. ...in Check() in c:/Windriver/workspace/WPILib/MotorSafetyHelper.cpp at line 123
I have that error and it repeats continuously on the driver station.
I am deploying SimpleRobot example code.
Any solutions?
int main()
::::::::: include=>commitment;
::::::::: int=>school name=>Asheboro::High
::::::::: int=>team name=>Kamikaze::Komets;
::::::::: Priority_Queue=>FRC Championship::2012;
::::::::: Max_Element=>Teamwork;
Unread 14-02-2012, 18:38
tlemmons tlemmons is offline
FRC #2083
tlemmons is an unknown quantity at this point
Re: Live C++ help
I dont know if you got this working but looking at your pictures you are plugged into the pins that they call multipurpose I/O and not the I2C port. They is the four pins closest to the NXT connector.
Unread 14-02-2012, 22:15
FRC #4174
Re: Live C++ help
Could You provide a picture? I'm not sure what your talking about
Unread 08-02-2012, 17:12
mikets's Avatar
Software Engineer
Re: Live C++ help
Bold = change.
By putting a 2 there, you are saying you have TWO digital modules which means you must have an 8-slot cRIO and the second digital module must be inserted in slot 6 of the 8-slot cRIO and your accelerometer is connected to the I2C of the digital side car that is connected to the digital module in slot 6. Is that really your configuration?
