Go to Post Hurricane season would be torture, at least in snow you can lock the doors and know the robot is safe. - rtfgnow [more]
Unread 08-02-2012, 14:11
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Usage of serial port on cRio
We're having a lot of difficulty using the serial port on the cRio to interface with devices.
  • Console out switch is off.
  • Tried with an RS232 compass sensor
  • Tried with an Arduino spitting out a single byte in a loop
  • Confirmed correct serial data on both devices with a logic analyzer and Portmon
When running some very simple code (I sure hope I'm just doing something wrong) - the cRio will read some data (slowly) and then crash.
virtual void TeleopPeriodic() {
  int n = com.GetBytesReceived();
  if (n > 0) {
      char *buffer;
      printf("Reading\n");
      com.Read(buffer, n);
      printf("Done reading\n");
      for (int i = 0; i < n; i++) {
          printf("%d 0x%X\n", n, buffer[i]);
Screenshot attached.
Unread 08-02-2012, 14:38
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Usage of serial port on cRio
I don't have Wind River in front of me at the moment so I can't verify the com class especially the Read method, but my instinct tells me that you declare buffer as a "char *" which means there is no buffer associated with it. buffer is an uninitialized pointer. If the Read method is going to put bytes into buffer, it is going to trash random memory locations.
I could be wrong
Unread 08-02-2012, 14:45
Emily Horsman
I could be wrong
Perhaps. But the data being printed is correct, however it's slow and crashes afterwards.
Unread 08-02-2012, 14:51
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
I could be wrong
Nope, you are 100% correct. They have declared/reserved no storage. Change char *buffer to char buffer[X] where X is big enough to hold the data. It should work then but it is a bit of a kludge, you probably want a bigger buffer declared as a global or allocate the memory so it is not on the stack (as all local variables are).
HTH
Unread 08-02-2012, 14:54
mikets's Avatar
Software Engineer
Of course it looks correct (at least before it crashed). Imagine the buffer pointer is pointing to some random memory, so the Read method will start copying the bytes to the random location. Your print loop will also print the bytes from this random location. But what is this random location anyway? What if the random location contains the return address of your function (which is very likely)? So at the end of your function when you are returning to the caller, since the return address is trashed, you returned to la la land, thus crashed.
Unread 08-02-2012, 16:34
Emily Horsman
Aha, this worked. Feeling quite silly now but thanks!
