Go to Post ...UFH nominations are like jello, there is always room for one more. - Barry Bonzack [more]
Unread 07-02-2012, 16:41
4085's Avatar
4085 4085 is offline
Technical Difficulties
AKA: Sebastian Brosious
FRC #4085 (Technical Difficulties)
4085 is an unknown quantity at this point
Buttons
How do you program buttons to activate an additional motor attached to your joystick? For instance, If I wanted to connect the trigger of our right joystick, where and how would we code that? We have a Logitech Attack 3 joystick and are using labview, if that helps.
Unread 07-02-2012, 18:20
WittyUsername's Avatar
WittyUsername WittyUsername is offline
FRC #3607 (Technologic)
WittyUsername is an unknown quantity at this point
Re: Buttons
Use the 'unbundle' tool. Wire the Joystick's button node to unbundle's node, and you should be good to go. If no options pop up at first, try right clicking the unbundle VI and add an element.
It should work just like the axes, except the buttons only return Boolean variables. Good Luck!
Unread 07-02-2012, 23:47
Re: Buttons
In Teleop
  1. position the cursor over the Buttons output node on the Joystick Get
  2. right-click for the menu
  3. Choose Cluster, Class and Variant
  4. Choose Unbundle By Name (the first choice)
  5. Place it on the Block Diagram to the right of the Joystick Get
  6. Wire the Joystick Get Button node to the Unbundle and you should see "Button 1" appear. Expand or change the button to get the buttons you want.
Unread 08-02-2012, 00:03
Rogue Leader Rogue Leader is offline
FRC #0696 (Circuit Breakers)
Rogue Leader is an unknown quantity at this point
Re: Buttons
Unbundle as the previous posts have mentioned, and then, to program a motor function, you can:
1.) Use a case structure to decide how the motor functions, or
2.) Use a true/false selector to pass through a number value; if all you're doing is controlling motor speed, this way is easier than a case structure.
Also, from what I hear, try not to go overboard with putting buttons on the joystick. Let the operator do most of the button pushing, and let the driver do , well, the driving! It makes the driver's job easier.
Unread 08-02-2012, 05:42
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Buttons
You can also check out this thread, Alan Anderson was nice enough to post a picture of what the Labview code should look like.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 08-02-2012, 16:58
4085's Avatar
Re: Buttons
thank you ALL but now our other issue stopping is the motor running for the shooter. We want to program the button on our joystick. We programmed it so there is 3 variable speeds and one button stopping each of these programs but also so we can re initate the program. TRUST ME we can stop the program (i.e. we have a button that stops teleop.vi completely so we need to re deploy it) thank you
-Team 4085 Technical Difficulties
