Go to Post Yes, good job being calm and asking about the validity of a rumor before fanning the flames and assuming the conspiracy must be true. - Greg McKaskle [more]
Unread 08-02-2012, 11:09
StealthMentor StealthMentor is offline
FRC #1802
StealthMentor is an unknown quantity at this point
Re: BaneBots Shorted, Now What Do I Do?
I thought we had a case shorted RS775, the motor ran fine for break-in, and for a while after that during testing. Then it seized and popped the fuse we had in-line. After taking the case apart to investigate (a problem I have had since a young age ) I discovered the culprit to be a common paper staple had gotten between the magnets and rotor. I removed the offending staple and reassembled the motor, and it works, but now there is some endplay in the shaft. On a side note these motors were shipped strait to our shop, and used only there (we do not have paper staples in our shop) everything is in three hole binders.
Unread 08-02-2012, 11:14
Andrew Lawrence
Posts: n/a
Originally Posted by fox46 View Post
For some reason I thought that was legit. Why am I surprised to see that happen?
Unread 08-02-2012, 11:24
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Dale(294engr],
Correct me if I am wrong, but you mention the RS-555 and RS-550. I was under the impression that the failures and case shorting was common place for the RS-775, and that the RS-550 has been a realitively good motor in the past.
Unread 08-02-2012, 13:32
Originally Posted by jwfoss View Post
Dale(294engr],
I've only heard complaints on the RS775-18, even; though when a non-FRC application was talking about using the RS775-12 I did suggest that they check for the case short just to be on the safe side.
Unread 08-02-2012, 14:39
Kohala2460's Avatar
Kohala2460 Kohala2460 is offline
AKA: Michael
FRC #2460 (Na Paniolo)
Kohala2460 is an unknown quantity at this point
QUICK FIX: CIM MOTOR. Nuff' Said.
We recieved our RS-775 motors and have despite all the forums saying they suck and never use them. We love them haha.
But to answer this forum. If replacing/shipping is an issue, maybe order another, or just replace is with a CIM motor.
2 CIM motor drive is just fine, unless you were trying to with with a mech. drive. otherwise if you are going with a 6-8-10-12-16 wheel drive, 2-3 CIM motors will serve just fine.
Unread 08-02-2012, 17:05
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
The motor cannot be fixed, the shorting method can keep it running for a little while, but the motor will be weaker and will soon fail again.
BaneBots' lead time is shorter if you don't get a gearbox. If you contact them directly about your failed motor, they might be able to ship out a replacement even faster.
I would recommend replacing the motors with BB550s, FPs, or am-0912s. The FP and AM, except the the 0673, more closely match the speed of the 775s, making them better candidates for drop in replacement, with the FP 9013 being the closest in power. The motors on your lift could be replaced with AM or BB if you need the FP on the shooter.
It sounds like you're using P60 transmissions, am I right? If so, only the block that the motor directly attaches to needs to change. If you have access to a mill, you could redrill mounting holes that have the right spacing, otherwise you could buy a 5xx mounting block or find a local team who is willing to loan or donate one to you.
Jason
Unread 08-02-2012, 17:09
RS775-18 273 watts
FP 0673 292 watts
FP 9013 209 watts
Unread 08-02-2012, 17:21
nitneylion452's Avatar
AKA: Joe Lee
RS775-18 273 watts
FP 0673 292 watts
FP 9013 209 watts
He was using Price is Right rules. "Closest without going over."
In all seriousness, I would absolutely contact BaneBots about a possible replacement and avoid self-fixes. Remember that if you open the motor (take off the case) it is no longer competition legal.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 08-02-2012, 17:28
Closest in power between the ones that I thought were a good choice based on speed. Going with a FP-0673 or BB550 would more likely need a gearing change.
Jason
Unread 08-02-2012, 18:16
Going with a FP-0673 ... would more likely need a gearing change.
It depends on how the motors are being controlled. You could make the 0673 "look" like a 775-18 by running it at a lower voltage to get the same torque and speed.
@dexo568: How are you controlling the motors?
Motor Calculator  build MCALC32ab 1/19/2012 610pm
M7-RS775-18 @ 12.00 volts:
   oz-in      Nm     rpm    rpm%    amps   watts out    watts in    eff%
     2.9   0.021   12663    97.4     4.0        27.4        48.0    57.0
FP 00801-0673 [MotorInfo4.1.PDF data] @  7.78 volts:
     2.9   0.020   12663    94.1     4.7        27.2        36.4    74.6
Unread 10-02-2012, 16:14
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Is this a problem with Banebots RS775-12's, or does it also affect the RS775-18?
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 10-02-2012, 21:47
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
The problem is with the RS775-18. Not sure about the -12's.
