Go to Post Curse you and your logic! - Koko Ed [more]
Unread 08-02-2012, 19:06
240 Animation's Avatar
240 Animation 240 Animation is offline
AKA: Celia and Brynn
FRC #0240 (T.E.M.P.E.S.T.)
Team Role: Animator
240 Animation is an unknown quantity at this point
Error Message
Whenever we try to render one frame, it gets to 99% (at the most) and then crashes with this message:
mental ray has encountered a fatal error and the application will now shutdown. The error is MEM 0.6 fatal 031008 : can't allocate 20971520 bytes
We've checked our memory in all areas and its sufficient. What's going on?!?!
Unread 08-02-2012, 19:10
Bax2996's Avatar
Bax2996 Bax2996 is offline
FRC #2996
Bax2996 is a jewel in the roughBax2996 is a jewel in the roughBax2996 is a jewel in the roughBax2996 is a jewel in the rough
Re: Error Message
The memory is never as efficient as it says it is. I know you have enough- but the truth is you need enough and more in order to render.
Unread 08-02-2012, 19:13
Team Role: Animator
Re: Error Message
4 gb is the recommened amount. We have five. This is getting a little frustrating. Thank you for your help.
Unread 08-02-2012, 19:16
Bax2996's Avatar
FRC #2996
Re: Error Message
It's fine.
Yeah, you may have to try rendering on another computer. I know it is frustrating, but we've had the same problems for a long time.
Some computers are just not capable of rendering complicated scenes.
Unread 08-02-2012, 19:28
Team Role: Animator
Re: Error Message
We would undoubtedly prefer to render on this computer, if only we could figure out what our issues specifically are.
Unread 08-02-2012, 19:31
Bax2996's Avatar
FRC #2996
Re: Error Message
Well, the problem seems to be the computer.
I'm sorry, I wish I could be of more help, but it really seems that you are going to have to render from a differant computer.
Unread 08-02-2012, 19:32
Team Role: Animator
Re: Error Message
Alright, thank you for your patientce(... I forgot how to spell it).
Unread 08-02-2012, 19:34
Bax2996's Avatar
FRC #2996
Re: Error Message
^.^ It's all good.
(It's patience if that helps any XD don't worry I can never spell "experiance")
Unread 09-02-2012, 17:59
rastermon rastermon is offline
FRC #0847
rastermon is an unknown quantity at this point
Re: Error Message
I know it's a bad renderer, but test that portion in the default scanline renderer. We ran into a complex particle scene a few years ago that was too much for Mental Ray. Or reduce your scene and render parts to see which object (if any) is causing the memory failure. Rendered elements with alpha channels can be recombined in post.
Unread 10-02-2012, 11:33
DaveC DaveC is offline
None #0250 (The Dynamos)
DaveC will become famous soon enough
Re: Error Message
Autodesk has a discussion of this error message. See
http://usa.autodesk.com/adsk/servlet...inkID=12544120
They give a few strategies for getting around it. Good luck.
-Dave
