Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Unread 08-02-2012, 15:33
theNerd's Avatar
theNerd theNerd is offline
FRC #3329 (Cam Bots)
Rookie Year: 2110
theNerd is an unknown quantity at this point
Connection Problems
Lately I've been having connection problems everytime I try to compile code to the cRIO. I have all the updates installed for Java and the most recent cRIO image. My computers network setup is using IPv4: 10.33.29.5 and subnet mask is set to 255.0.0.0. For some reason everytime I try to compile and run code - using netbeans our only IDE - we recieve the:
Network interfaces on host:
...... adress: 10.33.29.5 netmask: 255.255.255.254
Warning: host is not on same subnet as robot. May not be able to complete all communication with robot.
Connecting FTP @10.33.29.2
Remote OTA server does not match, upgrading
C:...\sunspotfrcsdk\build.xml:96 ... bunches of errors.
I see that netbeans is detecting an incorrect subnet mask, however the netmask on the computer is in the correct format. Could anybody help? Thanks
Unread 08-02-2012, 20:00
Re: Connection Problems
Run ipconfig /all and look for possible multiple IP address bindings to your network interface.
Unread 08-02-2012, 21:08
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Hey. My team always gets this error with the subnet mask. If you wanna send a screenshot, that would be greaaaat. IDK why this happens, but it really isnt a big deal.
First ping the crio with ping --IP address of your crio-- (an example would be ping 10.26.07.2) and make sure you have a good connection
Then do as follows:
open up command prompt
type ren C:\Users\--InsertYourUserNameHere--\Documents\NetBeansProjects\--InsertYourProjectNameHere--\suite\image.suite robot.suite
type ftp --IP of the crio-- (Example would be ftp 10.26.07.2)
type cd ni-rt
type cd system
type send C:\Users\--InsertYourUserNAmeHere--\Documents\NetBeansProjects\--InsertYourProjectNameHere--\suite\robot.suite
Reboot the crio
What you just did was exactly what NetBeans wanted to do, just you did it manually. You ftp-ed into the crio and manually replaced the code and rebooted. You have sucessfully uploaded code the right way yourself!
I was gonna write a batch file for you, but this is just quicker
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 09-02-2012, 14:16
theNerd's Avatar
Rookie Year: 2110
Originally Posted by dellagd View Post
Reboot the crio
WOw! I had no idea it worked like that. I'm a Linux user so I am very interested in the guts of how systems like this work. I'm not very knowledgable in the networking arena of computers yet, but I'll definitely try this out and see if it works. How do I get a screenshot on here?
Unread 09-02-2012, 15:00
theNerd's Avatar
Rookie Year: 2110
Here is the first time through. This one happened a couple times in a row. I tried to run the ftp and it stopped after I typed send - like it said something about recieving the robot.suite but just sat there for 10 min like that.
Out of the blue I unconnected the camera and tried to load a program onto the cRIO and it worked for some reason. So I plugged the camera back in and tried to reload a program; failure. So I reconfigured the camera and plugged it back into the radio and now everything is back to working. I'm not sure what the problem was from earlier. If anyone has any ideas then that would be of some great help. Thanks!
